| Author |
Message |
panningbros Regular
Posted: Thu Nov 01, 2012 6:00 pm Post subject: Can you identify?? |
Did Ford build a 4000 4-cylinder industrial version with a torque converter drive? I bought the rear end of a tractor and am trying to identify it. The clutch pedal has a rod connected to a small hydraulic valve on the side of the clutch housing. I need to try and identify what model this was. |
| Back to top |
cdmn Regular
Posted: Thu Nov 01, 2012 7:26 pm Post subject: Re: Can you identify?? |
I'm sure that they did. |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Thu Nov 01, 2012 7:55 pm Post subject: Re: Can you identify?? |
They built Airport Tugs with a torque converter but they were 2000 series with the 134 cu in engine. Do you have the transmission to look for the Model and Serial Numbers? |
| Back to top |
souNdguy Tractor Guru
Posted: Fri Nov 02, 2012 5:58 am Post subject: Re: Can you identify?? |
do you actually see the TC or is it the inching pedal of an SOS you have? |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1673 Location: Southeast PA
Posted: Fri Nov 02, 2012 7:44 am Post subject: Re: Can you identify?? |
The model number should be on top of the flat spot that faces up on the bell housing, up near the very front of the transmission housing. If it was a 4 cylinder it will be on the flat spot on the left side (when you're sitting on the tractor facing forward). If it was a 3 cylinder tractor it will be on the right side, but will also most likely have a number on the left side as well. These will not be raised casting numbers, they will be recessed numbers that were stamped into the metal . Post any numbers that you find in either of those 2 spots. |
| Back to top |
RickB Tractor Guru
Posted: Fri Nov 02, 2012 2:55 pm Post subject: Re: Can you identify?? |
I know of a forklift with a 134 engine and TC driven transmission. |
| Back to top |
showcrop Tractor Guru
Posted: Fri Nov 02, 2012 3:21 pm Post subject: Re: Can you identify?? |
A friend here in NH has 600 with a Torque converter. It was originally an airport tug. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
