6 volt coil
Dougct
PostPosted: Fri Nov 02, 2012 4:41 am    Post subject: 6 volt coil Reply to specific post Reply with quote
I had my generator re-wrapped to make it 12volt.I have a distributor,do i need to change my 6 volt coil to a 12 volt,also do i need to run a regulator or a cutout?Thank"s
Nebraska Cowman
PostPosted: Fri Nov 02, 2012 5:00 am    Post subject: Re: 6 volt coil Reply to specific post Reply with quote
You need to add an external resistor ahead of your coil.
DeltaRed
PostPosted: Fri Nov 02, 2012 5:46 am    Post subject: Re: 6 volt coil Reply to specific post Reply with quote
As Cowman says,you will need to add a resistor.If you don't do this,you will need to buy a new coil in about 3 hrs.Don't ask how I know this......"smokin"!
rustyfarmall
PostPosted: Fri Nov 02, 2012 6:13 am    Post subject: Re: 6 volt coil Reply to specific post Reply with quote
dougct wrote:
(quoted from post at 05:41:24 11/02/12) I had my generator re-wrapped to make it 12volt.I have a distributor,do i need to change my 6 volt coil to a 12 volt,also do i need to run a regulator or a cutout?Thank"s
You need to add an external resistor (cheapest way) or buy an internally resisted universal coil.
A coil that is labled for use on a 12 volt system STILL requires an external resistor.
TractormanNC
PostPosted: Fri Nov 02, 2012 7:43 am    Post subject: Re: 6 volt coil Reply to specific post Reply with quote
Use a regulator instead of the cutout. Your battery will live much longer.
old
PostPosted: Fri Nov 02, 2012 7:56 am    Post subject: Re: 6 volt coil Reply to specific post Reply with quote
You can replace your coil and get one that say no external resister needed or keep the coil you have an add a ballast resister like the O'Reilly's part # VR-1 which is small and easy to hide and the way it mounts you have a good heat sink so it lasts longer then most
