| Author |
Message |
Mr. T. Minnesota Regular
Posted: Fri Nov 02, 2012 5:20 am Post subject: voltage reg. placement and tire chains |
Forum Members,
Where is the best place to attach a voltage regular on a 2N? Want a place that is accessible. Any thoughts are welcome.
Another question, do tire chains come in different lengths? Had a set that fit 12.something X 28 tires on my 2N. Gave them away and had another set that came up short. I have another set and want to know to know what length the connecting chains have to be. Reason for the question is the chains are here in central Minnesota and 2N in NE Minnesota. Any help is appreciated.
Mr. T. Minnesota |
| Back to top |
souNdguy Tractor Guru
Posted: Fri Nov 02, 2012 6:10 am Post subject: Re: voltage reg. placement and tire chains |
accessible?
mount it to a flap hanging down from the hood by the dash..
or rig a bracket by the genny itself.. get the 2 workers together... |
| Back to top |
GB in MT. Tractor Guru
Joined: 17 Jun 2007 Posts: 5668 Location: Seeley Lake, Mt. (Home of "Hermie the 2N")
Posted: Fri Nov 02, 2012 6:26 am Post subject: Re: voltage reg. placement and tire chains |
Mr. T;
I hung my V/R, on the batt. plate, where the tool box is usually placed. Keeps it up under the hood, and out of the way, but with good access.
V/R....'blue colored box' in this pic.....:
Tool box went to the lft. rear fender.
Same charging system that you are using.....early 8N gen...with V/R, VRS. cutout!!
GB |
| Back to top |
JMOR Tractor Guru
Posted: Fri Nov 02, 2012 7:31 am Post subject: Re: voltage reg. placement and tire chains |
| Mr. T. Minnesota wrote: | (quoted from post at 09:20:21 11/02/12) Forum Members,
Mr. T. Minnesota | If it were my 9N/2N, I would mount it exactly where the first 12,500 9Ns had their voltage regulator mounted. Your newer style VR will have different mounting hole pattern than the 9N10505 VR had & different than holes in tractor casting, but it would be real easy to make a simple adapter plate. Only consideration is whether or not there is adequate space where your cut out was mounted. Because the 1939 tractors did not have the safety starter switch located just below that & thus would have more space. You will need to verify adequate space.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
