Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
clean rust pits?
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork
Jr. Roby
PostPosted: Sat Nov 03, 2012 6:06 pm    Post subject: clean rust pits? Reply to specific post Reply with quote
Is muriatic acid ok to clean metal prior to primer?if so how to cut it?
Stephen Newell
PostPosted: Sun Nov 04, 2012 4:57 am    Post subject: Re: clean rust pits? Reply to specific post Reply with quote
Personally I prefer sand blasting however muriatic acid will clean rust off especially if brushed with a brass brush. The problem is it will quickly rust back if not treated. It should be cleaned off with oxalic acid or vinegar, rinsed and dried afterwards. Then as soon as you get the moisture off of it, it should be primed with epoxy primer. Any surfacing or bondo work can be applied over the epoxy primer.
CNKS
PostPosted: Sun Nov 04, 2012 7:35 am    Post subject: Re: clean rust pits? Reply to specific post Reply with quote
NO, not a good idea, HCl is too strong, musst be washed off within a few minutes of application, and you will then get flash rust. You will consider Picklex 20 expensive, but you will use very little on the sheet metal and it will do several tractors. It does not need to be washed off, read the info in the link.
Picklex 20
showcrop
PostPosted: Sun Nov 04, 2012 6:56 pm    Post subject: Re: clean rust pits? Reply to specific post Reply with quote
You want phosphoric acid. Google it. It tells you about how it forms a protective film. You can get it at an auto parts store under many different names or spend 1/4 the money and get it at a dairy supply or restaurant supply where they sell it for removing mineral film. I spray it on, keep the part wet for 15 min, then rinse off well. I also use a bucket to dip small parts for 1/2 hour or so then rinse in a second bucket for ten min. It will get right down in the pits better than sandblasting to dissolve the rust.
souNdguy
PostPosted: Tue Nov 06, 2012 5:20 pm    Post subject: Re: clean rust pits? Reply to specific post Reply with quote
yep.. naval jelly or other phos acid containing prep.
hint.. some driveway cleaners that remove rust in a gallon jug for 9$ at lowes contain phos acid and will eat that rust.. then rinse and get working on that metal.. etc..
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
