| Author |
Message |
Mark Poss Regular
Posted: Sun Nov 04, 2012 4:20 am Post subject: Little Genius Plow |
Can someone tell me the correct way to set up the hitch on a little genius plow to pull behind a 37 John Deere A I have the plow manual but it only shows diagrams for older Farmalls. The plow is a two bottom with 14" shares. Thanks for your time, Mark. |
| Back to top |
Carlyle hoffman Long Time User
Posted: Sun Nov 04, 2012 4:57 am Post subject: Re: Little Genius Plow |
First set your plow draw bar (center) 23",s from the furrow wall, after you have made a short test furrow. Now set your tractor draw bar the same demention from the inside of your right rear tractor wheel, wheel will probably have to be moved in. When you make your first pass , check to see that your front coulter is cutting just 14",s from the furrow wall.You can change that by shorting or lengthening the plow hitch draw bar brace.From the back of the plow, your right hand lever sets your leveling and the other your depth ,if no hyd. cylinder is being used, meaning ground lift plow.Your coulters should be set 3/8s to 1/2" to the left of you points and coulter axel 2",s ahead of the points , if your bolt holes allow this to be done. Have fun. |
| Back to top |
Posted: Sun Nov 04, 2012 5:01 am Post subject: Re: Little Genius Plow |
Sorry, to clarify set your tractor right rear wheel 23",s from you tractor draw bar being (centered) on the tractor. , Sorry for the miss explanation, i goofed up. I knew what i wanted to say, just did not come out that way.. |
| Back to top |
Ron W Regular
Posted: Sun Nov 04, 2012 8:40 am Post subject: Re: Little Genius Plow |
Check this out...a manual on the lil genius plows
http://ia700409.us.archive.org/13/items/cu31924003310962/cu31924003310962.pdf
Untitled URL Link
| Back to top |
Bret4207 Tractor Expert
Joined: 15 Jan 2005 Posts: 3084 Location: St Lawrence Valley, Northern NY
Posted: Sun Nov 04, 2012 3:28 pm Post subject: Re: Little Genius Plow |
| Ron W wrote: | (quoted from post at 09:40:17 11/04/12) Check this out...a manual on the lil genius plows
Untitled URL Link
Hey Ron- THANKS!!! That manual was just what I've been looking for for some time. |
| Back to top |
mkirsch Tractor Guru
Posted: Mon Nov 05, 2012 5:43 am Post subject: Re: Little Genius Plow |
Why would the setup be any different for a JD vs. an IH?
All it should be is distance from the inside of the tractor's right rear wheel to the drawbar, and distance from the inside of the plow furrow wheel to the center of the plow. A few inches either way won't really make much difference. |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9502 Location: Wapakoneta, Ohio
Posted: Mon Nov 05, 2012 9:34 am Post subject: Re: Little Genius Plow |
Difference is the Ih is probably a wide tread in that the wheela are permantly set in the cultivating position for 2 40" rows or 80" wheel tread, more if the tractor has the 28" rubber on and can not be narrowed down like the Deere to about a 56" wheel tread. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
