| Author |
Message |
dflippin08 Regular
Posted: Sun Nov 04, 2012 11:35 am Post subject: Put the turbo on my 570 |
Just finished putting the turbo on my 570. I decided to turn it and run the exhaust out of the side. This made the install much easier for me. Plus my hood is already dented all up so I cant really hurt it. Just wanted to show some pics.
| Back to top |
Adirondack case guy Tractor Guru
Posted: Sun Nov 04, 2012 3:59 pm Post subject: Re: Put the turbo on my 570 |
Why didn't you rotate the turbo 90 degrees so that you could utilize the front outlet of the exaust manifold to support the exaust system, and utilize the existing hole in the hood? rather than having to cut a new hole in the side of the hood and then have to fab up a mounting system to support the exiting exaust from the Turbo on the LH side of the tractor hood and frame. What you did will work fine, but It won't look stock. I don't know what your plans are with the tractor, Pulling or what, but I like the looks of a "Sleeper". Just my two cents and that's all it is worth.
Loren |
| Back to top |
830 man Guest
Posted: Sun Nov 04, 2012 4:17 pm Post subject: Re: Put the turbo on my 570 |
Curious as to what turbo you used, or what it was originally used on. |
| Back to top |
dflippin08 Regular
Posted: Sun Nov 04, 2012 4:23 pm Post subject: Re: Put the turbo on my 570 |
If I had rotated it 90 degrees the inlet would have been too close to the fuel tank, unless i wouldve made a sadle for the turbo like you did. I dont have much exhaust pipe to support. Its only gona have a straight pipe with a 90 and a rain cap. The way i did it I didnt have to cut my intake or exhaust manifold, but my bent up hood will get a new hole. I will only using the tractor for work. There is 3 1/2 inches between the hood and the turbo, so I could still run it ouf the original hood hole if i wanted. Sometime in the next 2 weeks ill get it back on the dyno to see what the numbers look like. |
| Back to top |
dflippin08 Regular
Posted: Sun Nov 04, 2012 4:25 pm Post subject: Re: Put the turbo on my 570 |
It was used on a John Deere 5403 3cyl. 2.9L which I think had 74hp (Engine) |
| Back to top |
830man Guest
Posted: Sun Nov 04, 2012 4:42 pm Post subject: Re: Put the turbo on my 570 |
I would like to see the numbers it puts out. Any pump work? |
| Back to top |
1370rod Long Time User
Posted: Sun Nov 04, 2012 4:53 pm Post subject: Re: Put the turbo on my 570 |
Just curious, what HP are you looking for and what kind of work will the tractor be doing, Rod. |
| Back to top |
dflippin08 Regular
Posted: Sun Nov 04, 2012 4:55 pm Post subject: Re: Put the turbo on my 570 |
I havent done anything to the pump, but someone has. It turns 2400 at wot. I dont know if anything else has been done or not. Ive gota get the egt on it first. |
| Back to top |
Adirondack case guy. New User
Posted: Sun Nov 04, 2012 5:00 pm Post subject: Re: Put the turbo on my 570 |
I wasn't trying to knock your legs out from under you. I'm an old fart, forgot that the 530/70s had much larger fuel tanks: As I said, it will work well. Please post pics of the finished project, I'm sure you will be more than satisfied with the performance.
Loren |
| Back to top |
dflippin08 Regular
Posted: Sun Nov 04, 2012 5:25 pm Post subject: Re: Put the turbo on my 570 |
Im thinking it will make around 60hp. I dont really need anymore power than what I had, I just got the turbo and the tubing for free, so I had to use it. I have a tiller, a 4 bottum blow, blade, and a bush hog. I use it in hay, the garden, and game patches. |
| Back to top |
Jason Kozlowski Long Time User
Joined: 14 Oct 2007 Posts: 523 Location: Glen Rock, PA
Posted: Sun Nov 04, 2012 7:14 pm Post subject: Re: Put the turbo on my 570 |
Just a look at what it takes to run the exhaust through the original hole.
| Back to top |
dflippin08 Regular
Posted: Mon Nov 05, 2012 4:27 am Post subject: Re: Put the turbo on my 570 |
I wish that I had a turbo exhaust manifold. flip |
| Back to top |
j hikemper Guest
Posted: Mon Nov 05, 2012 6:23 am Post subject: Re: Put the turbo on my 570 |
GREAT WORK !!...if any of you gurus find another turbo i have a candidate for the next upgrade.. |
| Back to top |
kwoodrum Guest
Posted: Mon Nov 05, 2012 11:52 am Post subject: Re: Put the turbo on my 570 |
lets us know how much hp you make, i dont think i will do that to my 570 they are to hard to find, we have a 530 i would like to do someday |
| Back to top |
kwoodrum570 Guest
Posted: Mon Nov 05, 2012 12:03 pm Post subject: Re: Put the turbo on my 570 |
we have a 530 i put a 207 i would like to turbo it someday |
| Back to top |
