| Author |
Message |
Nick in MD New User
Posted: Sun Nov 04, 2012 3:17 pm Post subject: How do you run alt/gen when water pump is removed? |
On an IH H how are you guys running the alt/gen when the mechanical water pump is removed?
thanks
nick |
| Back to top |
ricky c Regular
Joined: 05 Mar 2009 Posts: 267 Location: west columbia sc
Posted: Sun Nov 04, 2012 3:35 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
hang it from under the motor run off the crank |
| Back to top |
Nick in MD New User
Posted: Sun Nov 04, 2012 3:40 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
thanks, anyone else got anymore good ideas |
| Back to top |
E V Ward New User
Posted: Sun Nov 04, 2012 3:50 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
Thats the only way unless you leave it up top with a long belt. I have mine under the bottom and its easy to do that way. |
| Back to top |
6pack Regular
Posted: Sun Nov 04, 2012 4:12 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
I do not use 1, buy a good optima battery and trickle charge over night before pull, we ran no alt. when racing roundy round for 100 laps |
| Back to top |
Nick in MD New User
Posted: Sun Nov 04, 2012 5:22 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
thanks for the help guys |
| Back to top |
H-66 Regular
Posted: Sun Nov 04, 2012 5:39 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
I run an electric fan and water pump in my H with no alternator. I got a Yellow top optima battery and good charger with an AGM setting. Charge it the night before the pull and you are good to go. |
| Back to top |
baldwin racing Regular
Posted: Mon Nov 05, 2012 5:12 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
machine a bracket with a shaft to hold a bearing free spinning pulley. that sits in the same spot that the stock water pump pully was and leave alt in stock spot? if you dont want to run it underneath...just an idea?
kelly |
| Back to top |
Posted: Mon Nov 05, 2012 5:14 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
pulley with a high speed bearing in it....so its free spinning with no drag....
what i ment to say in post above
kelly |
| Back to top |
Nick in MD New User
Posted: Mon Nov 05, 2012 11:23 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
Having no alt with msd boxes there is still enough battery for a day of pulling? |
| Back to top |
Superih Long Time User
Posted: Tue Nov 06, 2012 6:19 am Post subject: Re: How do you run alt/gen when water pump is removed? |
| Nick in MD wrote: | | (quoted from post at 00:23:57 11/06/12) Having no alt with msd boxes there is still enough battery for a day of pulling? |
A high compression engine with MSD will not run correctly without 13 to 14 volts. That being said if you only start your tractor a couple times a fully charged battery should be good. Multiple starts throughout the day drains a battery very quickly. Pulling takes horspower, why let a 15 lb alternator rob you of it?
Also in my opinion Optima batteries are not that great. Odyssey batteries are the best made, Sears Platinum batteries are a rebranded Odyssey at about $100 less. |
| Back to top |
Eddie Ward Regular
Posted: Tue Nov 06, 2012 6:34 am Post subject: Re: How do you run alt/gen when water pump is removed? |
I don't think so. If you have a high output fan and do much cranking I think it would kill your battery. |
| Back to top |
S.D.L. Regular
Posted: Tue Nov 06, 2012 4:51 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
I second that motion that Optima batteries aren't that great. Just a Johnson Controls battery with a lot of advertisement. |
| Back to top |
Dalet Long Time User
Posted: Wed Nov 07, 2012 4:06 pm Post subject: Re: How do you run alt/gen when water pump is removed? |
| S.D.L. wrote: | | (quoted from post at 19:51:45 11/06/12) I second that motion that Optima batteries aren't that great. Just a Johnson Controls battery with a lot of advertisement. |
Bring along a 3500lb tractor to pull start it and forget the battery...  |
| Back to top |
