| Author |
Message |
selfsuffgrdnr New User
Posted: Sun Nov 04, 2012 5:07 pm Post subject: More Questions About A |
Well I've had my A for about two weeks now. Thanks everyone for the help regarding the implements.
I've now got a plow but its for a Super A. I know now that it is a completely different setup. This is the plow with the two long springs on the front.
So the question is this...
Can I drop my drawbar on the brackets and make it so it pivots, hook up the plow and then attach a chain from the drawbar to a point on the tractor (cultivator lever bolt points?) to use a depth control?
I don't want to do anything dangerous. It seems like this would work just like the depth control on the Super A except for the point that it wouldn't be very automatic.
I'm also having to use a comealong to lift the plow up because though I have some parts I cannot figure out the lift on the rear.
Jason |
| Back to top |
gene bender Tractor Guru
Posted: Mon Nov 05, 2012 2:56 am Post subject: Re: More Questions About A |
You should be able to turn the drawbar forward letting it hinge on the large bolt for depth control. Or make the framework that bolts to the steering sector to hook the beam to. I have the lever that controls the depth also one to raise and lower the plow but its here in Easern Iowa also have the rockshaft but not the assy that goes from the rockshaft to the beam. |
| Back to top |
PretendFarmer Regular
Posted: Mon Nov 05, 2012 4:25 am Post subject: Re: More Questions About A |
Your best bet would be to find the original implements. They are out there.
Hooking a plow to the draw bar on that tractor wont work. If it does, not well. I doubt that it will even go in the ground at all.
Do you have the lift? If so, look up binder books and get the implement manual. It is not hard to bolt the lift on.
| Back to top |
Posted: Mon Nov 05, 2012 4:30 am Post subject: Re: More Questions About A |
If you can, post pics of all your levers and stuff that you have. Maybe I can figure out where it goes. |
| Back to top |
Posted: Mon Nov 05, 2012 6:26 am Post subject: Re: More Questions About A |
| gene bender wrote: | | (quoted from post at 03:56:33 11/05/12) You should be able to turn the drawbar forward letting it hinge on the large bolt for depth control. Or make the framework that bolts to the steering sector to hook the beam to. I have the lever that controls the depth also one to raise and lower the plow but its here in Easern Iowa also have the rockshaft but not the assy that goes from the rockshaft to the beam. |
Gene
That was my thought, but like Pretend said, it may not work. All I can do is try.
Jason |
| Back to top |
Posted: Mon Nov 05, 2012 6:28 am Post subject: Re: More Questions About A |
Pretend
I looked at your picture you posted last time on my message and it doesn't match what I bought on Saturday. I might have gotten the cultivator hookups? Not sure. I mean some pieces are there but others are not. I'll try to take a picture tonight and post it.
Trust me if I could find the implements made for it I would gladly use them but there is simply not a good source of implement down here in KY. Plenty of fasthitch and plenty of three point hitch but no Farmall A implements.
Jason |
| Back to top |
Posted: Mon Nov 05, 2012 7:27 am Post subject: Re: More Questions About A |
They are out there. I had to go to the next state over to get mine. Perhaps when we see thepics of what you have, some ideas on making something work will come up. |
| Back to top |
David R Inman Regular
Posted: Mon Nov 05, 2012 7:56 am Post subject: Re: More Questions About A |
I have no idea if he has any implements or how far he is from
your location (from what i understand he's not very far into
ohio) but he is a good salvage tractor part source, trusdell
farm parts 937 549 4201 |
| Back to top |
Kevin Happke Regular
Posted: Mon Nov 05, 2012 10:03 am Post subject: Re: More Questions About A |
Hello Gene, What is the condition of 2 or 4 row veggie cultivator that you have and how many shovels do you have for it?
Thanks, Kevin |
| Back to top |
Posted: Mon Nov 05, 2012 10:09 am Post subject: Re: More Questions About A |
Hello Jason, Give me a call at 320-468-6474 this evening it easier to discuss this on the phone than type it all here....Thanks, Kevin |
| Back to top |
stumper Regular
Posted: Wed Nov 07, 2012 6:11 pm Post subject: Re: More Questions About A |
thank you for sharing that picture i could never figure out how that hooked up on the back of my A
Thanks again, stumper |
| Back to top |
Posted: Thu Nov 08, 2012 5:57 am Post subject: Re: More Questions About A |
Luckily I have the implement manual. I bought it cause the tractor came with A plow and a pile of levers, bars and stuff. Turns out the plow was not from an A.
The manual came in handy when I bought a plow from someone with all the levers, and brackets. |
| Back to top |
