Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
2020 dies when less than a quarter tank
Post new topic    Yesterday's Tractors Forum Index -> John Deere
J-bear
PostPosted: Sun Nov 04, 2012 7:53 pm    Post subject: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
I have a 2020 gas. When the fuel gets below around a third to a quarter tank, the engine will sputter for a few seconds and die, especially under load. It will usually restart and run for a few seconds and do the same thing. It will keep doing that until I fill the gas tank up, disconnect the fuel supply line at the carb, and crank the engine for 10-12 seconds (dumping fuel onto the ground). Sometimes I have to do the disconnect and crank routine a couple of times before it stops the sputtering, then it runs like a top until the fuel gets low in the tank again. I don"t think it"s the carb, as I recently had that rebuilt and it runs perfectly until the fuel gets low. I thought maybe the fuel pump is starting to go bad, so tonight I pulled that off and cycled the lever with my thumb over the intake port. It seemed to be generating good suction (I could hear a tiny "pop" when I pulled my thumb off).
There has always been some wetness on one of the connections where the fuel line connects to the pump. I"m guessing that the tiny leak was letting air into the line, preventing the pump from pull enough fuel when not aided by gravity when there was enough fuel in the tank?
Any other ideas?
Cliff Nelson
PostPosted: Sun Nov 04, 2012 8:41 pm    Post subject: Re: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
Repeat the fuel pump test with your finger over the outlet port. Should be pressure there. there are two check valves in the pump and you only tested one of them. Your symptoms indicate a bad fuel pump.
MSD
PostPosted: Sun Nov 04, 2012 9:23 pm    Post subject: Re: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
Bad fuel pump!
David G
PostPosted: Mon Nov 05, 2012 6:48 am    Post subject: Re: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
Fuel pump, $35
Jim Skala
PostPosted: Fri Feb 22, 2013 3:10 pm    Post subject: Re: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
I bet the fuel filter right before the carb is partially plugged up with dirt.
buickanddeere
PostPosted: Fri Feb 22, 2013 5:13 pm    Post subject: Re: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
Fuel pump and filter.
The filter is hidden in the gas line elbow.
Tx Jim
PostPosted: Sat Feb 23, 2013 3:54 am    Post subject: Re: 2020 dies when less than a quarter tank Reply to specific post Reply with quote
T19743 FILTER,GASOLINE FUEL ADD 12.87 USD
RE43274 PUMP,FUEL TRANSFER,ASSEMBLY ADD 82.79 USD
