Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Re-addressing the oil dipstick NAA
Post new topic    Yesterday's Tractors Forum Index -> Ford
LeoinMI
PostPosted: Mon Nov 05, 2012 8:32 am    Post subject: Re-addressing the oil dipstick NAA Reply to specific post Reply with quote
After reading the previous post on the oil capacity of a NAA,(5qt or 6qt.) depending on the length of the dipstick,..I got to thinking,(Which can be dangerous for me). I assume if you have the 11.25 inch dipstick ,you must first start the tractor and let it run to get oil into the filter and THEN check the oil level to see if it is on the full mark. Checking the oil cold would result in an overfill on the stick of about 3/4qt since the filter takes an extra quart and drains back into the oilpan..
Am I way off on this or just complicating things? Just trying to clarify for future oil changes.
Dean
PostPosted: Mon Nov 05, 2012 9:40 am    Post subject: Re: Re-addressing the oil dipstick NAA Reply to specific post Reply with quote
Yes. You must start the engine to allow the filter to fill and then allow the oil to drainback into the pan to achieve an accurate level check after an oil and filter change.
Cold (non oil change) level checks are accurate because most filders do not drain down upon shutdown due to check valves and/or air locks.
Dean
George Marsh
PostPosted: Mon Nov 05, 2012 5:57 pm    Post subject: Re: Re-addressing the oil dipstick NAA Reply to specific post Reply with quote
LEO,
I have an NAA, Jubilee. The spin on filter will drain back only about a quarter of an inch on the dipstick after it sits for a long time. If my menory is correct, I only bought a 5 quart bottle of synthetic oil from Wal-mart. I have a splash left in the bottle because the spin on filter doesn't take a full quart. There was no need for me to buy extra oil, because my engine doesn't use oil. I went with synthetic oil because the filter drains back and takes 10-15 seconds after sitting to fill the filter and build oil pressure. I even use NAPA gold filter, still drains back. Removed filter to confirm it drains back.
If I remember, I'll measure the length of my dipstick tomorrow.
I would think if you put an extra quart of oil in engine, it might come out someplace.
I accidently overfilled a 13 hp honda engine and it smoked like crazy.
George
LeoinMI
PostPosted: Tue Nov 06, 2012 8:31 am    Post subject: Re: Re-addressing the oil dipstick NAA Reply to specific post Reply with quote
I have the original style filter on my NAA George with a Wix cartridge filter inside the canister.(See attached Picture). I just assumed the original canister filter drained back somewhat due to it being on a 90 degree angle to the engine block. Thus causing a higher reading on the dipstick even when checked cold.
JMOR
PostPosted: Tue Nov 06, 2012 9:43 am    Post subject: Re: Re-addressing the oil dipstick NAA Reply to specific post Reply with quote
LeoinMi wrote:
(quoted from post at 12:31:05 11/06/12) I have the original style filter on my NAA George with a Wix cartridge filter inside the canister.(See attached Picture). I just assumed the original canister filter drained back somewhat due to it being on a 90 degree angle to the engine block. Thus causing a higher reading on the dipstick even when checked cold.
There was a diaphragm between block & filter with a hole positioned toward the top. This prevented drain back to the pump below the level of the hole. However, other than the tight clearance/oil film at bearings, there was nothing to prevent drain back through the center outlet of filter.....this should take a very long, nearly infinite period of time in a non-worn out engine & even then get you down to a half full filter. The FORD spin on adapter has a similar hole at the top. As for the anit-drain back flapper valve incorporated in spin on filters, in my observation those are not much of a valve! Some seem a little better than others, but I would not expect any of them, even 'original' Motorcraft to hold for much time.
