Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
8N Governor
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
JCinKY
PostPosted: Mon Nov 05, 2012 8:52 am    Post subject: 8N Governor Reply to specific post Reply with quote
Been doing some small projects on the 50, front mount, 6v these past few weeks. Haven't used it all that much or worked it hard at all.
I've been noticing that the engine will throttle up nicely to about 3/4, but struggles and stumbles at anything past that. I cannot get it to WOT. My carb is adjusted correctly and runs really sweet until 3/4 throttle.
What I see is that once it hits about 3/4, the governor will push the throttle plate toward the wide open position even though the dash throttle lever has not moved. When I bought the tractor the tab for the governor spring was broken on the linkage arm and the spring was held on by some tie wire; i did not touch it.
My question is how much, if any, spring tension should there be at idle and the governor in the "home" position? I will be checking the electrical and putting in new/cleaning the points before it gets too cold. Plugs are AL 437, new less than 20 hours on them.
HCooke
PostPosted: Mon Nov 05, 2012 10:53 am    Post subject: Re: 8N Governor Reply to specific post Reply with quote
Governor spring should have no preload or slack at
the closed position.
JCinKY
PostPosted: Mon Nov 05, 2012 11:58 am    Post subject: Re: 8N Governor Reply to specific post Reply with quote
Good. Thanks.
Looks like I will be adjusting the governor tonight. The bearings and shaft were good, but the balls did have some flat spots. Think I will rebuild this winter, if this doesn't improve things.
HCooke
PostPosted: Mon Nov 05, 2012 3:09 pm    Post subject: Re: 8N Governor Reply to specific post Reply with quote
Flat spots on the balls are a more likely cause of
your symptoms.
JCinKY
PostPosted: Mon Nov 05, 2012 3:53 pm    Post subject: Re: 8N Governor Reply to specific post Reply with quote
HCooke wrote:
(quoted from post at 16:09:53 11/05/12) Flat spots on the balls are a more likely cause of
your symptoms.
So if I understand the function if the gov...crank turns gov, balls ride on plate, as balls get further away gov opens throttle? The balls are the weights and flat spots give intermittent/improper function?
Sure it needs a thorough going through just don't want to miss the small things.
teddy52food
PostPosted: Mon Nov 05, 2012 5:58 pm    Post subject: Re: 8N Governor Reply to specific post Reply with quote
As the balls get farther away they CLOSE the throttle.
HCooke
PostPosted: Mon Nov 05, 2012 6:03 pm    Post subject: Re: 8N Governor Reply to specific post Reply with quote
With the tractor running. Grab the gov to carb rod
and open up the carb. The gov should fight you. When
you have gov off the tractor. Spin the gear with
your fingers and you will sell the gov arm pull back
away from where the carb would be.
JCinKY
PostPosted: Tue Nov 06, 2012 10:12 am    Post subject: Re: 8N Governor Reply to specific post Reply with quote
Gotcha...thanks for the info. I have disconnected the gov completely and it did take full throttle. The gov seems to be acting up and either dumping too much gas or restricting it at different times. Gonna put a set of points in for the winter (cheap) and fix the governor so it'll work when I need it.
