| Author |
Message |
FarmerZeb Regular
Joined: 05 Jan 2012 Posts: 278 Location: Missouri - North Callaway County
Posted: Mon Nov 05, 2012 6:20 pm Post subject: Disc problem |
I have a 3pt 8' krause disc that doesn't seem heavy enough to get more than an inch or so in to my heavy clay / loam bottom ground. This is the only disc i've ever had so i don't have any comparison. The disc is in good shape no broken disks and very minimal rust. I was thinking that it is just too light a disc for this particular ground. Would a heavier wheel type disc be the ticket?
i am a no till operation and only break out the disc to smooth out ground where required
thanks
paul |
| Back to top |
BCnT Tractor Expert
Posted: Mon Nov 05, 2012 7:41 pm Post subject: Re: Disc problem |
i keep a few old Ford 460 engines around to put on my 6.5' 3 point disk when i need to in hard ground...weight is the answer most of the time. |
| Back to top |
tbish Regular
Posted: Mon Nov 05, 2012 11:22 pm Post subject: Re: Disc problem |
your disc was designed to follow a plow did u plow first |
| Back to top |
maxwell99 Long Time User
Posted: Tue Nov 06, 2012 4:23 am Post subject: Re: Disc problem |
Only disc I ever saw that would disc in hard ground.
It was a 20 ft. Disc with the two 4 ft. Sections folded up over the disc for extra weight.
It would cut good in hard ground pulled by a Jd 4320. |
| Back to top |
FarmerZeb Regular
Posted: Tue Nov 06, 2012 4:49 am Post subject: Re: Disc problem |
yes plowed it with 2-14's |
| Back to top |
DiyDave Tractor Guru
Posted: Tue Nov 06, 2012 4:56 am Post subject: Re: Disc problem |
Try putting serrated or notched discs on it, in the front, should make it penetrate better, but wear faster. |
| Back to top |
BushogPapa Tractor Guru
Posted: Tue Nov 06, 2012 5:01 am Post subject: Re: Disc problem |
On plowed ground, you should have a problem with keeping the disc from going in too deep...
Are you sure your 3-point is allowing the disc to drop all the way..??
Is the disc rusty to the point that the discs are not cutting cleanly..?
As said before, you might need to add some weight to it..a few cement blocks, rocks, etc..?
Ron.. |
| Back to top |
Ellis Kinney Long Time User
Posted: Tue Nov 06, 2012 8:54 am Post subject: Re: Disc problem |
I would suggest trying it with the top link disconnected. I also have a piece of railroad rail to put on mine. Ellis |
| Back to top |
David G Tractor Guru
Posted: Tue Nov 06, 2012 10:13 pm Post subject: Re: Disc problem |
I have a 10' Krause disk that behaves the same way, I am going to add weight to the disk. I am thinking about 500 pounds.
My H will pull it without weight, gonna use the 6610 on it with weight. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
