| Author |
Message |
Gariana Guest
Posted: Tue Nov 06, 2012 7:50 am Post subject: E Gleaner Engine |
I have a few questions about this engine. Will they run 2300rpms and handle it well? And do these engines have a set speed gov or do I need a gov from a WD/45/D17? Im planing to put one in a tractor this winter so if anyone has one running id be interested. Im in SW Indiana. Thanks. |
| Back to top |
jbp Long Time User
Posted: Wed Nov 07, 2012 7:08 am Post subject: Re: E Gleaner Engine |
The throttle on those engines only over rides the governor. As far as holding up at 2300 RPMs, I doubt they would stay together for long at that speed as that is nearly 50% above factory governed speed. Factory governed speed was 1650.
Joe |
| Back to top |
cleddy Regular
Posted: Mon Nov 12, 2012 10:10 am Post subject: Re: E Gleaner Engine |
I put an Gleaner E engine on a WD-45 tractor. I had the old tractor engine and transfered the Governer mechanisim over to the gleaner engine but kept the spin-on Oil Filter. It is a good upgrade since the combine engines are almost free and more powerful engines. You should try to do it right with the correct control linkages.
cleddy |
| Back to top |
Gariana Guest
Posted: Mon Nov 12, 2012 10:53 am Post subject: Re: E Gleaner Engine |
Ok thank you I was going to use this engine in something other than a Allis. I have a belt driven gov that ill try out. |
| Back to top |
c leddy Regular
Posted: Mon Nov 12, 2012 6:25 pm Post subject: Re: E Gleaner Engine |
Well okay. That is a different story.2300 Rpm is out of the question but they were made to run at a governered speed all day long as the other reader mentioned 1650 RPM(not confirmed). On a combine there is idle speed and then operating speed wide open and it is governed or the engine would blow up on a down hill turn which it doesn't do. Sure at half throttle there is control but maybe not as good as a Allis tractor would have but then sounds like you have your own project you are trying. Go for it and good luck.
cleddy |
| Back to top |
mike a Guest
Posted: Sat Nov 17, 2012 8:38 am Post subject: Re: E Gleaner Engine |
use the tractor gov.assembly,buy a 175 allis tractor gov.spring about$40,this should give you about 2000 rpm's no-load. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
