| Author |
Message |
BigTone Regular
Posted: Tue Nov 06, 2012 10:04 am Post subject: Is this how the thermostat fits? PICS |
Hey guys, though i had the thermostat upside down but when i pulled it all apart it looks like i have it right. tractor was getting hot I just want to eliminate this problem first.  |
| Back to top |
George Cameron New User
Posted: Tue Nov 06, 2012 10:08 am Post subject: Re: Is this how the thermostat fits? PICS |
The thermal capsule (copper colored tubular part of stat) should go toward the source of heat.
What a huge bypass port!
Last edited by George Cameron on Tue Nov 06, 2012 10:16 am; edited 1 time in total |
| Back to top |
Mike Groom Long Time User
Posted: Tue Nov 06, 2012 10:37 am Post subject: Re: Is this how the thermostat fits? PICS |
You have it in backwards,the bulb end should be in the engine block or it won't open properly. |
| Back to top |
BigTone Regular
Posted: Tue Nov 06, 2012 11:01 am Post subject: Re: Is this how the thermostat fits? PICS |
| Mike Groom wrote: | | (quoted from post at 19:37:40 11/06/12) You have it in backwards,the bulb end should be in the engine block or it won't open properly. |
Jim, do any of these pics look right, it looks like you can not have it upside down because then the two thermostat housing pieces can not be bolted together...
I am looking at it and I cant flip it around, the first picture is of the lower thermostat housing with the thermostat fliped and it does not fit, the second picture is of the upper thermostat housing and it has a round recess for the tube part of the thermostat, am I missing something or do i have the wrong thermostat? I know i ordered one for an M. thanks for the help guys
| Back to top |
D Slater Tractor Expert
Posted: Tue Nov 06, 2012 11:44 am Post subject: Re: Is this how the thermostat fits? PICS |
Picture is the way that type themostate goes.
Doesn't it have a arrow on the side that says to radiator? Looks like the same one NAPA sells. |
| Back to top |
BigTone Regular
Posted: Tue Nov 06, 2012 11:46 am Post subject: Re: Is this how the thermostat fits? PICS |
I new it had to be, im going to check the thermostat in a pot of boil water to see if anything opens up |
| Back to top |
pete 23 Tractor Expert
Posted: Tue Nov 06, 2012 11:48 am Post subject: Re: Is this how the thermostat fits? PICS |
You had it in correct, as you can see it will not
go the other way. If that tube fits into it's hole
in upper housing freely it will more than likely
leak around it and definetely not stick.
Here is what I would do now that you have it off,
is take fan belt off so water pump won't turn,
fill as much coolant as you can get in right at
the engine. Start engine and coolant should not
move. If it rises up you have a combustion leak
causing heating problem. You have to do this
quickly as it will start to rise as soon as it
warms so you have less than maybe a minute to take
a look. |
| Back to top |
kevinj54 Long Time User
Joined: 04 Mar 2008 Posts: 567 Location: West Michigan
Posted: Tue Nov 06, 2012 11:49 am Post subject: Re: Is this how the thermostat fits? PICS |
Put a thermometer in the pot. Stat should be open by 180° or sooner, not 212°(boiling water) |
| Back to top |
BigTone Regular
Posted: Tue Nov 06, 2012 12:03 pm Post subject: Re: Is this how the thermostat fits? PICS |
Just put it in and it looked completly open by 180 degrees. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
