Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
451 vs 504 crank strength
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
Die Hard Case
PostPosted: Tue Nov 06, 2012 4:57 pm    Post subject: 451 vs 504 crank strength Reply to specific post Reply with quote
I am looking to bore our 451bdt to a 504 is the crank in 451 the same as 2670 crank or should I just look for a the so call big journal 504?
1370rod
PostPosted: Tue Nov 06, 2012 5:26 pm    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
Bingo, get a later 504 with the larger crank. These blocks also give you the piston cooling oil spray which helps the engine live at much higher HP. Will need the bigger oil pump also. 504 blocks in 20 and 2290 tractors had the small crank like the 451, Rod.
1030 TOM
PostPosted: Wed Nov 07, 2012 5:22 am    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
friend of mine made a pro stock puller out of a451 lasted 3 pulls he went to a504 crank has lasted 3 yrs
RGMartin
PostPosted: Wed Nov 07, 2012 5:48 am    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
Have you ever seen a broken crank on a "farm use" small journal that wasn't turned up or abused?
1030 TOM
PostPosted: Wed Nov 07, 2012 6:01 am    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
I have got a 1030 with a451 out of a 1175 this tractor makes 168 hp on two diferent dynos ran it for 10 yrs never no trouble dont know if it would live any higher good luck
Die Hard Case
PostPosted: Wed Nov 07, 2012 3:39 pm    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
Thanks guys this is for a pulling tractor. The tractor already dynos out at over 300 with the 451 but I plan on doing more exstensive engine work to get to the 600hp range and I was just worried about the smaller crank taking the extra rpms and heat. So if I find a good crank out of a 15 26,2590 or 4690 it will go right in my block without any machining the block? I would just like to do this the right way the first time. Thanks Jason
Thad
PostPosted: Wed Nov 07, 2012 4:14 pm    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
No a large journal crank will not fit your block. Thats what makes them stronger is the larger journals. You just need to find a complete 504 from the models you just posted. This will give you the later screw in injector heads also. Your smaller crank has 2.75 rod journals and 3 inch mains. The larger crank is 3 inch rod and 3.5 mains. Thad
pump ?
PostPosted: Wed Nov 07, 2012 5:46 pm    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
The oil pumps are differnt between the engines?
1370rod
PostPosted: Wed Nov 07, 2012 7:52 pm    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
The engines with the piston oil spray use a higher volume pump. Example 20 and 2290 with a 504 have the small crank and smaller oil pump, 23 and 2590 have large crank high volume pump and oil spray. The 1470 had large crank, no spray and small pump. Early 12 small crank, small pump, no spray. Late 12 had small crank ,BIG pump and spray. Are you confused yet? Early 13 was like the 14. Late 13 all 15,24 26, 23,25, 44, 46 all had big crank, big pump and spray. Rod.
Thad
PostPosted: Thu Nov 08, 2012 3:11 am    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
Hey Rod i didnt think the 1270s ever had piston cooling on them since they were all 451s. But i dont think i ever worked on a very late one either. Thad
1370rod
PostPosted: Thu Nov 08, 2012 5:47 am    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
I was surprised to see that also, it would be to only non 504 engine that I know that had it, Rod.
Die Hard Case
PostPosted: Fri Nov 09, 2012 5:13 pm    Post subject: Re: 451 vs 504 crank strength Reply to specific post Reply with quote
I have a 1470 engine that I have acces to would it be better to find a 504 with the oil spray to take the extra heat or just put the high volume pump in ad call it good? I plan on rebuilding the motor anyhow I not that sure if it will create that much heat in one pass down the track to hurt anything too much. Any input is always helpfull Thanks guys Jason
