| Author |
Message |
Grandpots New User
Posted: Wed Nov 07, 2012 5:03 am Post subject: Coil or carb |
I"ve always heard carburettors are usually the very last thing to
blame. So I am thinking about my problem is with the coil (and
a lot easier to work with). The problem is my 2000 ford 3-cyl
gas tractor (1967??) will start up really good and run for about
4-5 minutes. Then will die and after a minute or so will start
and run (I do choke it again before hitting the starter) really
good again for a few minutes. What should I do? Grandpots |
| Back to top |
JMOR Tractor Guru
Posted: Wed Nov 07, 2012 5:36 am Post subject: Re: Coil or carb |
| Grandpots wrote: | (quoted from post at 09:03:31 11/07/12) I"ve always heard carburettors are usually the very last thing to
good again for a few minutes. What should I do? Grandpots | 4 to 5 minutes isn't long enough to heat up much of anything of much mass, so I'm not thinking heat, myself. What is history? Did it run just fine until yesterday? Has this been something that gradually got worse over time? Have there been any recent changes to the tractor? |
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18497 Location: Southwest Iowa
Posted: Wed Nov 07, 2012 6:03 am Post subject: Re: Coil or carb |
| Grandpots wrote: | (quoted from post at 06:03:31 11/07/12) I"ve always heard carburettors are usually the very last thing to
It's a fuel issue. Might be an obstruction in the tank. Might be you need to clean the sediment bowl or change the fuel filter. Might even be a problem inside the carb. |
| Back to top |
souNdguy Tractor Guru
Posted: Wed Nov 07, 2012 6:20 am Post subject: Re: Coil or carb |
dityto what jmor said.
gradual or allof a sudden.
any custom wireing repalcing the resistor wire to the coil.. any custom fuelline routing, etc |
| Back to top |
Grandpots New User
Posted: Wed Nov 07, 2012 6:32 am Post subject: Re: Coil or carb |
Thanks guys...the things I have done ...replaced air filter(took
care of hard to start), new set of points, cleaned out sediment
bowl but couldn't find the replacement filter or would have (it's
a strange looking filter with lots of little washer like thingys
stacked on top of each other????). And that's about it. The
carb looks a bit hard to remove and I don't know where all the
filters are that might need replaced???? |
| Back to top |
Grandpots New User
Posted: Wed Nov 07, 2012 7:07 am Post subject: Re: Coil or carb |
Yes I did seem to come on fairly quickly??? |
| Back to top |
Grandpots New User
Posted: Wed Nov 07, 2012 7:18 am Post subject: Re: Coil or carb |
I meant to ask which coil should I use? |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9852 Location: Western Montana
Posted: Wed Nov 07, 2012 7:33 am Post subject: Re: Coil or carb |
I wouldn"t zoom in on the coil per se being the problem.
Check the spark by pulling the center wire out of the distributor ccap and holding it near a good ground , try a start. You should have a FAT, BLUISH-WHITE SPARK, the color of lightning. if you do, then most likely the ignition isn"t the problem. Look athe fuel delivery.
If you don"t have th requisite spark, I"d look at the entire primary ignition circuit-battery to ignition switch (solenoid connection if it has one)to the coil to the distributor to ground. Corrosion at connections, maladjusted burned, corroded or oily points, corroded ignition switch, etc. Check the resistance of the primary part of the coil. For a 12 V it should be around 3.2 ohms and for a 6 volt it should be around 1.6 ohms. If you have a 12V system and your coil is 1.6 ohms, you"ll need a ballst resistor in the primary circuit to limit the point current to ~4 amps max. |
| Back to top |
Dell (WA) Tractor Guru
Posted: Wed Nov 07, 2012 7:46 am Post subject: Re: Coil or carb |
Grandpots........it aint'chur sparkies, ittz'chur gasoline TANK VACUUM. Yer carby has about 5-mins of gas run time. Once it runs outta gas, guess what??? It stops running. Because it takes about 1-min fer the air to suck'em-back up into the gastank to relieve the VACUUM and then gravity refills the carb float chamber to run fer 'nutter 5-mins and DIES. Sometimes you need a NEW GAS CAP 'cuz the breather valve scheme gitts CLOGGED. .........Dell |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1676 Location: Southeast PA
Posted: Wed Nov 07, 2012 10:56 am Post subject: Re: Coil or carb |
To test Dell's theory about the gas cap vent being clogged, simply remove the gas cap and see if it'll run more than 5 minutes. If so, case closed. If not, it's not the gas cap. |
| Back to top |
mhb@ufe Long Time User
Joined: 05 Mar 2009 Posts: 959 Location: Jefferson Maine
Posted: Thu Nov 08, 2012 8:18 am Post subject: Re: Coil or carb |
You might want to disconnect the fuel line from the shut off valve under the gas tank and check the fuel flow coming out of the tank. The shut off valve has a screen that goes up in the tank and they are known for the screen falling off so that dirt gets in the outlet and plugs it.
Mark |
| Back to top |
Grandpots New User
Posted: Thu Nov 08, 2012 4:07 pm Post subject: Re: Coil or carb |
I finally found it...a wire barely making connection to my ignition . You couldn't see it z d I found the problem by giving a small tug on the wire and bingo the connection was apart. These things are really hard to find and by reading your posts started looking for the not so obvious...THANKS So Much once again life is good...my tractor is running and the wife is in A good mood😊
Charley....Grandpots |
| Back to top |
