Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4000, hyd system don't want to lift implement
Post new topic    Yesterday's Tractors Forum Index -> Ford
Paticia Bell
PostPosted: Wed Nov 07, 2012 4:39 pm    Post subject: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
got a 4000 ford tractor, and the Hyd systems
doesn't want to lift an implement, what is the
first thing I should have checked out in this
Royse
PostPosted: Wed Nov 07, 2012 4:47 pm    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
Start with the easy stuff. Is it full of fluid? Is it the right fluid and clean?
patricia bell
PostPosted: Wed Nov 07, 2012 4:49 pm    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
Ok, failed to mention,yes, checked all fluid
and levels, all good,,,
shaun wallace
PostPosted: Wed Nov 07, 2012 5:58 pm    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
Is it 3 cyl or 4 cyl? If 3cyl 8 speed or Select-o-speed
sixbales
PostPosted: Thu Nov 08, 2012 3:56 am    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
The transmission and rear end are separate reservoirs. The hydraulics draw fluid from the rear end. Many people check the transmission fluid level with the transmission dipstick, and think they"ve checked the rear end fluid level as well. Just in case this is your situation:
There are two small SQUARE HEADED fluid level check plugs on the right hand side of the trans and rear end.
As you are seated on the tractor, the transmission check plug is above your right toe.
The rear end check plug is behind your right heel. Difficult to see - you may have to squat down to see it.
These are small SQUARE HEADED pipe plugs. Pull them out and add fluid until it comes out of the hole.
souNdguy
PostPosted: Thu Nov 08, 2012 4:46 am    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
more info.. 3 or 4 cyl?
dbNga
PostPosted: Thu Nov 08, 2012 7:00 am    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
Did this problem just happen or has it been getting worse? What temp is it outside? Will it lift the implement at all or just very slow? If it's cool outside and you have 90 wt hyd fluid, that could be your problem. 134 hyd fluid will give instant result in cold temps.
ZANE
PostPosted: Thu Nov 08, 2012 2:34 pm    Post subject: Re: 4000, hyd system don't want to lift implement Reply to specific post Reply with quote
If it is a four cylinder 4000 take the fill plug out and with a good light and trying to lift an implement on the lift arms see if fluid is coming out the open end of the ram cylinder.
If it is you need to replace the ram cylinder piston rings.
Zane
