| Author |
Message |
IaLeo Guest
Posted: Wed Nov 07, 2012 5:51 pm Post subject: What would it be? |
Looking for a small, lightweight possibly cordless tool to drill small holes for finishing nails and other delicate nailing jobs. I break 1/16 dia. bits alot because the cordless drill is too slow and my handling is too wobbly. I have a gas powered finish nailer but I find it splits oak trim. Leo |
| Back to top |
Steve A W Regular
Joined: 11 May 2006 Posts: 330 Location: Northwest Indiana
Posted: Wed Nov 07, 2012 6:01 pm Post subject: Re: What would it be? |
Just cut the head off the size nail Your using
and chuck that in the drill.
It won"t break, maybe bend.
Then just chuck up another one.
Good Luck with Your project.
Steve A W |
| Back to top |
60 acre hillside Long Time User
Posted: Wed Nov 07, 2012 6:09 pm Post subject: Re: What would it be? |
Old fashioned "Yankee" push drill. Probably not find one in any store. |
| Back to top |
nys Guest
Posted: Wed Nov 07, 2012 6:18 pm Post subject: Re: What would it be? |
You don't mention what guage nailer you have, is it a finish nailer or brad nailer? Years ago I had the same problem and bought a brad nailer for smaller work. All window and door casing gets nailed with brads on the thin side and finish nails on outside. Caution a nailer that shoots brads and narrow crown staples has a larger anvil that makes a bigger hole and splits the wood. Since I have a bunch of Dewalt cordless tools I have the 18 volt finish nailer and brad nailer and love them and so do my guys no body uses a pneumatic gun if the Dewalts are around. Kind of tics me off when I gotta go looking for my own tools. |
| Back to top |
dandeere Regular
Posted: Wed Nov 07, 2012 6:29 pm Post subject: Re: What would it be? |
Hey IaLeo have I got a deal for you. Go to sears and ask for a nail spinner, chuck that in your drill, stick the finnish nail in the spinner and push. It leaves it about 1/4 inch up. Wack it with the hammer and set it. Done. They used to be under $5, and were made by Vermont. Dan |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Wed Nov 07, 2012 6:47 pm Post subject: Re: What would it be? |
Smaller the bit the higher the speed is what I was told, so I would think any cheap 2500 RPM drill would be appropriate since you wouldn't need a lot of power.
Zach |
| Back to top |
Ralph, Ohio Regular
Posted: Wed Nov 07, 2012 7:05 pm Post subject: Re: What would it be? |
You might want to try a Dremel tool. They come corded or cordless. It would have a lot less "leverage" & weight than a standard drill which could help in avoiding broken bits. |
| Back to top |
DiyDave Tractor Guru
Posted: Thu Nov 08, 2012 4:38 am Post subject: Re: What would it be? |
Try this, if you are hand hammering in finish nails: Turn the nail point up, on a hard surface, and dull the tip of the nail. Don't wail away on it, and bend the nail, just tap, and dull the tip flat. The flat surface will tear the wood fibers just enough to let the nail go in without splitting. |
| Back to top |
Maark Guest
Posted: Thu Nov 08, 2012 1:00 pm Post subject: Re: What would it be? |
Trim the head of your finish nail and chuck it in your drill, then use it to dril your holes. Use a good finish nail to complete the job. |
| Back to top |
Jason the Red Long Time User
Joined: 12 May 2009 Posts: 712 Location: Grain Valley MO
Posted: Fri Nov 09, 2012 5:22 pm Post subject: Re: What would it be? |
Excellent tip!! Not many people know to use this method. I have used it for years and it actually kept me in a job for a while as I was the only guy that could get some chair rail installed without cracking it all over. |
| Back to top |
MeAnthony Regular
Posted: Sun Nov 11, 2012 3:40 am Post subject: Re: What would it be? |
Sounds like a nail spinner would do the trick. I have one, works nicely. I'm not sure if it would handle 1/16" nails or if there are different size spinners.
Hope this helps,
Anthony
Nail Spinner
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
