Minneapolis moline
Kyle.H
PostPosted: Wed Nov 07, 2012 8:19 pm    Post subject: Minneapolis moline Reply to specific post Reply with quote
So i have a oliver g1355 with the 585mm motor how do you get the cam out? It looks like i have to pull the cam gear to get at another plate off, does this sound right? The reason I"m doing this is the key on the crank gear has slop and knock when you crank it. I got the tractor not running and got it going but it is bad every exaust valve hit the pistons for awhile it mushroomed out the tops of the pistons not sure what went first or is someone put it together wrong once and then put it right, any way it is a mess, any help would be great
Thanks Kyle
agcodick
PostPosted: Fri Nov 09, 2012 4:11 am    Post subject: Re: Minneapolis moline Reply to specific post Reply with quote
Kyle.H wrote:
(quoted from post at 21:19:33 11/07/12) So i have a oliver g1355 with the 585mm motor how do you get the cam out? It looks like i have to pull the cam gear to get at another plate off, does this sound right? The reason I"m doing this is the key on the crank gear has slop and knock when you crank it. I got the tractor not running and got it going but it is bad every exaust valve hit the pistons for awhile it mushroomed out the tops of the pistons not sure what went first or is someone put it together wrong once and then put it right, any way it is a mess, any help would be great
Thanks Kyle
Go to agcopartsbooks.com and sign in under "guest". Then search for G-1355. It will give you all the breakdowns of the parts. It is very helpful to see how they are put together.
Dick
mmmmmmmmmmmmmmmmmmmmm
PostPosted: Sun Nov 11, 2012 6:07 am    Post subject: Re: Minneapolis moline Reply to specific post Reply with quote
The cam will come out the front without taking the gear off. If you have the internal pump you have to take it out or if it has the tach drive you will have to take it out. You also have to have the lifters pushed up.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
