Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
3000 hydraulic pump part 2
Post new topic    Yesterday's Tractors Forum Index -> Ford
Ultradog MN
PostPosted: Thu Nov 08, 2012 11:18 am    Post subject: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
I'm still not getting this pump to bleed properly and/or the lift arms to stop chattering.
They say if you aren't much of a mechanic keep changing parts till you find the problem.
I have had 3 different pumps on this tractor, including an NOS pump that I have. They all do the same thing.
I have had both ends of the suction line off, cleaned them with lacquor thinner and gooped them with silicone.
I have bled about 3 gallons of oil out of the pump - high speed, low speed.
I blew lacquer thinner through the suction line to possibly clean out the filter.
Getting frustrated here.
What should I do?
leej
PostPosted: Thu Nov 08, 2012 12:40 pm    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Ultradog MN wrote:
(quoted from post at 20:18:16 11/08/12) I'm still not getting this pump to bleed properly and/or the lift arms to stop chattering.
What should I do?
Take it and $50,000 to JD dealer & be sure lift works before you take the new 'green' one home. That or build yourself a wooden tractor, that you can fix. Laughing
Vito
PostPosted: Thu Nov 08, 2012 12:46 pm    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Any pinhole leaks in the lines?
Vitoi
Ultradog MN
PostPosted: Thu Nov 08, 2012 2:22 pm    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Well, I don't know what I did but it started working properly. Darned things!
I had put the old pump back on and let it run about 1k rpm for a while.
Dunno.
I will run it again tomorrow to see if it holds prime. Hope so. I wish I knew why it wouldn't prime before though. Just to better unterstand it all.
Thanks to all!
RickB
PostPosted: Thu Nov 08, 2012 2:38 pm    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Silicone usually causes more problems than it ever fixes. New o-rings of the proper size and clean, smooth surfaces on the suctioon tube and adapter where the seals contact are necessary.
Bern
PostPosted: Thu Nov 08, 2012 4:11 pm    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
I've had more than one of those pumps do exactly what you describe. One thing is for sure, they don't bleed very fast.
Hobo,NC
PostPosted: Thu Nov 08, 2012 4:20 pm    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Ultradog MN wrote:
(quoted from post at 02:22:37 11/09/12) Well, I don't know what I did but it started working properly. Darned things!
Dunno.
Thanks to all!
Just the same as mine did... Like magic it quit chatter'n... I had replaced all the O-rings in the hydraulics except any internal to the pump... It chattered so bad I you would thing something was in a binde...
I do not buy into a o-ring leaking on the suction tube were it enters the rear case in my opinion you can rule that one out as a possible issue...
Greg Wolodkin
PostPosted: Sun Nov 11, 2012 4:49 am    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Glad to hear you got it working. When you put the new pump back on, how much priming did you do? I ask because I've done all the things you mention except for the silicon, and then some.. actually removed and cleaned the suction filter, replaced the paper filter, replaced all O-rings in the lift cylinder and all the square-cut seals on both ends of the plumbing to the pump. Lift works but chatters.
Maybe it will work its way out of that funk, but if I can accelerate the process ...
flyingace
PostPosted: Sun Nov 11, 2012 7:40 am    Post subject: Re: 3000 hydraulic pump part 2 Reply to specific post Reply with quote
Ultradog MN wrote:
(quoted from post at 15:22:37 11/08/12) Well, I don't know what I did but it started working properly. Darned things!
Dunno.
Thanks to all!
Don't want to rain on your parade, but mine does this as well. I think I have it fixed because it's working every time I start it up. The next thing I know, it won't lift - have to prime it again. Hopefully, yours is permanent.
Since mine is just a chore tractor, I live with it. But I have to admit, not knowing what's causing it irks me.
