| Author |
Message |
larry duda Regular
Posted: Thu Nov 08, 2012 4:55 pm Post subject: 4010 upper drawbar support bracket repair |
Here are some pictures of how we repaired the rear pto housing cover-upper drawbar support bracket without removing the cover. Sure beats splitting the tractor. They must of had trouble with this style, as they changed it on the 4020's.
| Back to top |
Roger in Iowa Long Time User
Posted: Thu Nov 08, 2012 6:45 pm Post subject: Re: 4010 upper drawbar support bracket repair |
Any details on how and what you made it out of? |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13151 Location: Coyote Flats,Tx
Posted: Fri Nov 09, 2012 4:03 am Post subject: Re: 4010 upper drawbar support bracket repair |
| larry duda wrote: | | (quoted from post at 20:55:05 11/08/12) Here are some pictures of how we repaired the rear pto housing cover-upper drawbar support bracket without removing the cover. Sure beats splitting the tractor. |
Yes the rear drawbar support can be removed just by unbolting. They have been known to break from operators running tractors with the attaching bolts loose for long periods of time.
When I stated in your other thread that tractor would require splitting you stated pto housing. FYI the rear drawbar support is not associated with the rear pto quill as tractors without pto still had drawbar support.
I'm glad you got it repaired. |
| Back to top |
Mike M Tractor Guru
Posted: Fri Nov 09, 2012 10:45 am Post subject: Re: 4010 upper drawbar support bracket repair |
Is that U shaped piece all new additions ? I forget how our 4020 looks ?
If it is all new won't it throw off your 3 pt. hitch width ? |
| Back to top |
Tx Jim Tractor Guru
Posted: Fri Nov 09, 2012 11:14 am Post subject: Re: 4010 upper drawbar support bracket repair |
| Mike M wrote: | (quoted from post at 14:45:33 11/09/12) Is that U shaped piece all new additions ? I forget how our 4020 looks ?
Nothing in above photos will change 3pt draft arm spacing. |
| Back to top |
larry duda Regular
Posted: Sat Nov 10, 2012 4:31 pm Post subject: Re: 4010 upper drawbar support bracket repair |
This does not change the dimensions for the width at all. The u shaped piece is still the original one off the tractor. The busted casting that is seen laying on the floor is the upper piece of casting that was broken. I cut it off the rear cover. I cut the casting off with a good cut off tool, removed the bottom u shaped piece from the tractor and welded a new piece of flat into it after I drilled the matching holes in it. Larry |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
