Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
farmall 400 2nd shift lever ?
jim_uny
PostPosted: Thu Nov 08, 2012 6:54 pm    Post subject: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
what is shorter shift lever under tach ?
Nebraska Kirk
PostPosted: Thu Nov 08, 2012 7:31 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
Hmmmm.....that is a puzzler... I have never seen one of those.
Have you tried moving the lever to see what it does?
DeltaRed
PostPosted: Thu Nov 08, 2012 7:40 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
You may have an 'expermental' tractor.What does the SN say?Never saw anything like that
Janicholson
PostPosted: Thu Nov 08, 2012 7:47 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
If it is photoshopped into the picture it is a neat spoof. If it is there and not hooked to anything, it is a neat spoof. If it connects to something, it is going to be new to me (and probably Wardner as well!!!!!!!. Look inside. There is an access plate there with identical mounting holes, so get on the tractor and shift that stick. It would be nice if it was a 2 speed auxiliary with a 50% reduction. Jim
Nate V. IA
PostPosted: Thu Nov 08, 2012 9:05 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
I could be wrong but I think Wardener posted that picture this morning, now on the second page, about a 400 Tachometer. The same question was asked, I am anxious for an answer as well. He has some interesting modifications and enjoy all of his posts. My favorite being the swing over the tire traction lugs.
Nate
KIP in MX
PostPosted: Thu Nov 08, 2012 11:28 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
Looks like the top cover off a cottonpicker tractor. Now let's hear from Wardner.
Wardner
PostPosted: Thu Nov 08, 2012 11:33 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
Photobucket
Another shot.
I've wondered why nobody in the last four years has never asked me about the smaller shifter. Alot of people have seen that tractor in person. I sometimes think that collectors go to shows for only the social aspects. OTOH, that tractor has two Electralls so maybe the shifter goes unnoticed. Been thinking about four Electralls. The last two would run off the LPTO driven gear at the bottom of the center section.
I had an extra shifter. I figured someday I would use it to shift something. I have been thinking about an axle locker using a heavy jackshaft and two gears connecting the bull gears. One pinion gear would slide on splines, the other would be fixed. It could also run a hydraulic valve.
Someone mentioned the swing over traction aids. They do draw alot of attention. They are on a different 400. They were made in Canada. I have never seen another pair.
Photobucket
Wardner
PostPosted: Fri Nov 09, 2012 12:21 am    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
Kip,
All the row crop 400,450,560 as well as the 300 etc have cotton picker lids except they are not machined on the inside for the opposite side shift rails. That tractor does have a Cotton Picker PTO though. I found the PTO in Bakersfield, CA.
Photobucket
One lid is SMTA. The other is 560.
the tractor vet
PostPosted: Fri Nov 09, 2012 7:34 am    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
Now them TRACTION AIDS i could have used the last four days . Back when i was a pup my uncle farmed with crawlers and the one advantage was we really did not have a traction problem with them. Everything was done with them the plowing discing planting cultivating and harvest.
KIP in MX
PostPosted: Fri Nov 09, 2012 9:31 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
Thanks for the explanation!
*IHMMJD*
PostPosted: Sun Nov 11, 2012 7:00 pm    Post subject: Re: farmall 400 2nd shift lever ? Reply to specific post Reply with quote
I have a 400 cotton harvestor and my shift lever is also on the right side, but nothing in the left side. It is shorter than a normal shifter, but not as short as yours
