Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Bad selenoid? Bad starter?
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
jmead9
PostPosted: Fri Nov 09, 2012 6:19 am    Post subject: Bad selenoid? Bad starter? Reply to specific post Reply with quote
on my 1950 8N, 6v, sidemount distributor. I get a 'click-click-click' when trying to start it from my selenoid. Battery is fully charged as I bought a charge/load tester and have checked it myself. The battery is less than 3 months old. I have pulled starter and made sure that the mounting surface on block and the starter itself is clean and fine. I have brand new cables (and the proper ones) and I do not have a problem with a ground. The starter is pretty much brand new as well and it is the proper one. What is my next step? I don't want to just start throwing new parts at it.
Bruce (VA)
PostPosted: Fri Nov 09, 2012 6:30 am    Post subject: Re: Bad selenoid? Bad starter? Reply to specific post Reply with quote
"I don't want to just start throwing new parts at it. "
Ahhhhh, troubleshooting first before buying parts? That's the correct approach. Too bad we don't see more of it around here! :)
If you are 100% sure everything else checks out, then jump the solenoid.
I'm not saying that's the problem; the solenoid is making a noise because of low voltage. That is likely caused by:
1. A weak battery (charge it & check it per tip # 49))
2. Dirty grounds/connections (remove the cables & clean the connections)
3. Bad cables or incorrect sized cables (replace them - see tip # 41)
4. Bad ground between the starter & the block. (pull the starter away from the block & clean the mating area - see tip # 36)
Jumping directly to the starter is also a good test. (but see tip # 43 first)
50 Tips
souNdguy
PostPosted: Fri Nov 09, 2012 5:46 pm    Post subject: Re: Bad selenoid? Bad starter? Reply to specific post Reply with quote
ditto that.
put in neutral.. block clutch..
hook jump cables up red to bat hot.. black to starter stud.
stand back distance of cables and touch red black together .. that way real hard to get rund over if you forgot 1 and 2..
old
PostPosted: Fri Nov 09, 2012 5:49 pm    Post subject: Re: Bad selenoid? Bad starter? Reply to specific post Reply with quote
New batteries are not always good batteries learned that many years ago when I got a new one and installed it and got nothing out of it. Check all battery cable connections as to being clean and tight. Pull the battery side cable off the solenoid and try putting it on the starter side and see if it will then spin the engine over. Check and double check to it is out of gear when you do that
ASEguy
PostPosted: Fri Nov 09, 2012 8:38 pm    Post subject: Re: Bad selenoid? Bad starter? Reply to specific post Reply with quote
Love your "stand back" advice. :>)
souNdguy
PostPosted: Sat Nov 10, 2012 12:27 pm    Post subject: Re: Bad selenoid? Bad starter? Reply to specific post Reply with quote
yep.. the average person won't listen half the time to the put in neutral and block clutch comments before they take a screwdriver or pair of channelocks to a solenoid. but when telling them how to wire something.. the jump cables make a good 6+' stand back device.. so if it does move.. they don't have to be near a tire...
Ken(Ark)
PostPosted: Sat Nov 10, 2012 2:24 pm    Post subject: Re: Bad selenoid? Bad starter? Reply to specific post Reply with quote
ASEguy wrote:
(quoted from post at 00:38:42 11/10/12) Love your "stand back" advice. :>)
I would leave it in gear , key on , gas open wide , and ask my brother in law to test with the jumper cables , just saying .....
