| Author |
Message |
john in the highlands Regular
Joined: 05 Jun 2012 Posts: 35 Location: The Highlands of Ontario, Canada
Posted: Fri Nov 09, 2012 9:34 am Post subject: snowblower for mf35 |
Is a 750 lb agro trend 2072 (6' cutting width) to heavy for the deluxe gas mf35? The mfg web site says min. 30 hp max 40 hp. I don't like to run over unblown snow, it's 5 1/2' to the outside of my rear tires. Thanks for your input! |
| Back to top |
garymck Regular
Posted: Fri Nov 09, 2012 9:46 am Post subject: Re: snowblower for mf35 |
I have both a T035 and a MF35 and I use a different make of blower that weighs 545 pounds but is 6 feet wide. No problem! |
| Back to top |
Dan S (NY) Long Time User
Posted: Fri Nov 09, 2012 9:54 am Post subject: Re: snowblower for mf35 |
I use a 6' blower on my MF50 which has the same engine and three point capacity as the 35 and it works great. The 50 has a heaver front end than the 35 so your steering may get a bit light with the blower raised.
Dan |
| Back to top |
495man Long Time User
Joined: 12 Jun 2007 Posts: 1053 Location: Nova Scotia, Canada
Posted: Fri Nov 09, 2012 1:02 pm Post subject: Re: snowblower for mf35 |
You might find the front light at times, but it should be workable. Low Reverse is ideal for snow blower on the MF's.
Do NOT travel at road speed with the blower on if the front end is light..you don't have normal steering grip, especially on snow/ice.
I run a 78" on a MF 240 |
| Back to top |
to_many_irons Regular
Joined: 01 Sep 2010 Posts: 290 Location: new brunswick
Posted: Fri Nov 09, 2012 8:11 pm Post subject: Re: snowblower for mf35 |
i got 7 foot blower on a 202 .
i take my 28 inch tires of and put 24 on to slow her down .
there just cross chains on the rears tires will be loaded for this winter .
there is a loader on her so the front end is not light .
the only thing there is no cab .
it worked good .
there will be no carbon build up . |
| Back to top |
Posted: Sat Nov 10, 2012 6:45 am Post subject: Re: snowblower for mf35 |
thanks guys, I took my loader off for repairs, my front tires are also loaded. I want to put on a brush guard/bumper and also be able to attach weights to it. I'm thinking 100 lbs weight to balance the load. |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Sat Nov 10, 2012 7:40 am Post subject: Re: snowblower for mf35 |
When I was near Canada like Dan S is, my 6 foot 3 point farmking blower worked just fine. Now that I am further south and closer to the ocean, the snow falls wet and thick, and the blower is useless as designed, it just pushing the muck along like a mechanized blade.
I find a loader with wide bucket gets me cleaned out fast, then a scraper blade finishes up. Use a blower here, and it would all melt before I could finish job. |
| Back to top |
Posted: Tue Nov 13, 2012 8:20 am Post subject: Re: snowblower for mf35 |
seems puma snowblowers are 300 lbs lighter for the 6' wide model. They're made in quebec canada I believe. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
