| Author |
Message |
PaGlenn Regular
Posted: Fri Nov 09, 2012 3:20 pm Post subject: John Deere STX38 Idle adjust |
I just got a Deere Stx38 (black deck). It is idling too high with the fuel lever in the low setting. It has the Kohler Command 13 engine. |
| Back to top |
JT Tractor Guru
Posted: Fri Nov 09, 2012 5:44 pm Post subject: Re: John Deere STX38 Idle adjust |
if you cannot set static idle down, look for an air leak,or a throttle butterfly bent not allowing throttle to go shut all the way. kinda hard to diagnose something without a little more info |
| Back to top |
PaGlenn Regular
Posted: Fri Nov 09, 2012 6:29 pm Post subject: Re: John Deere STX38 Idle adjust |
I just picked it up today. with the Pto engaged it idled the motor down enough for me to cut the lawn. Motor starts without any problems. I will have to pick up a manual though. I will also check the carb butterfly and linkage. |
| Back to top |
JT Tractor Guru
Posted: Sat Nov 10, 2012 7:38 am Post subject: Re: John Deere STX38 Idle adjust |
With that extra info, i would also check governor spring, linkage or governor itself, if it was running away with itself and the PTO slowed it down enough to mow, sounds like ur issue might be governor related...good luck. If u want to.post ur email, i can send u a PDF file of the manual tomorrow. |
| Back to top |
PaGlenn Regular
Posted: Mon Nov 12, 2012 4:31 pm Post subject: Re: John Deere STX38 Idle adjust |
Emailid is glennscott47@gmail.com
Thanx for your input JT |
| Back to top |
JT Tractor Guru
Posted: Mon Nov 19, 2012 5:45 pm Post subject: Re: John Deere STX38 Idle adjust |
check your email |
| Back to top |
JT Tractor Guru
Posted: Mon Nov 19, 2012 5:46 pm Post subject: Re: John Deere STX38 Idle adjust |
it is the complete Kohler ser manual for the CV single series engines |
| Back to top |
PaGlenn Regular
Posted: Wed Nov 21, 2012 2:51 pm Post subject: Re: John Deere STX38 Idle adjust |
Got the PDF file. Thanx JT |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
