Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
NAA electric question..
Post new topic    Yesterday's Tractors Forum Index -> Ford
upnorthwi
PostPosted: Fri Nov 09, 2012 6:50 pm    Post subject: NAA electric question.. Reply to specific post Reply with quote
1954 NAA 6 volt
Just noticed on the new NAA that when you pull the headlight switch it instantly kills the tractor.
Any ideas and where do I start looking first?
JMOR
PostPosted: Fri Nov 09, 2012 7:50 pm    Post subject: Re: NAA electric question.. Reply to specific post Reply with quote
upnorthwi wrote:
(quoted from post at 22:50:40 11/09/12) 1954 NAA 6 volt
Check for bad/weak connections, most likely in the path between the lights and the battery, including battery ground. i.e., some connection is good enough to carry ignition current alone, but not good enough to carry ignition plus lighting current.
Sean in PA
PostPosted: Sat Nov 10, 2012 3:39 am    Post subject: Re: NAA electric question.. Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 23:50:06 11/09/12)
Or a dead short to ground somewhere between the headlight switch and the lights themselves. I would disconnect the battery and do some testing with a meter. You don't want to keep draining the battery with a short like that if that is the problem.
Disconnect the wire at the headlight end and with the switch off, measure resistance from the headlight end of the wire to ground. Should be infinite resistance. If it shows any resistance below infinite then you've got a short to ground somewhere between the switch and the headlights (or inside the switch itself).
Then with the wire still disconnected, measure the resistance from the switch to the headlight end of the wire. That should read close to zero ohms. Anything more that a couple tenths of an ohm and there's a problem with the wire like corrosion, rust, dirt or a loose connection somewhere.
souNdguy
PostPosted: Sat Nov 10, 2012 3:19 pm    Post subject: Re: NAA electric question.. Reply to specific post Reply with quote
my guess is your headlamps are run thru the ignition switch and it's not up for it / has a bad connection.
offload them from the ignition.. let it just handle the coil, and exciting the alternator if it has one.. :)
source power for the lamps on the same side of the ammeter as the ignition switch is drawing from to preserve your net charge / discharge setup
36 Coupe
PostPosted: Fri Nov 16, 2012 3:35 am    Post subject: Re: NAA electric question.. Reply to specific post Reply with quote
Headlite switch should have a fuse on it.No fuse, a short in the headlite wiring would kill the engine when you turn on the lites.
