| Author |
Message |
R Wyler Long Time User
Posted: Fri Nov 09, 2012 9:39 pm Post subject: 504 engines and heads I am curious?? |
I do know that the engines like the 504 on my 705 is a big bell and then the G1000s and so forth have small bell engine I have read some on this forum about that. I was thinking that the 504 engines were basically the same. Unless I read it wrong my manual shows a head for the non diesels with 9 studs instead of 7?? For the G1000 g900s ect. I am just curious about this. |
| Back to top |
Jeff Gravert Regular
Posted: Mon Nov 12, 2012 4:55 am Post subject: Re: 504 engines and heads I am curious?? |
The early spark ignition engines used 7 head bolt studs and then one 1/8" pipe per head that supplied oil up to the rockers. The later engines that used the 30 series cylinder heads (10A4230, 10A4231, 10A4232 etc.) had the same 7 head bolts but the 1/8" pipe was replaced with a gun drilled head bolt stud and another normal stud in the same position on the other end of the head. Hope this helps. Jeff |
| Back to top |
jd plowboy Long Time User
Posted: Mon Nov 12, 2012 10:17 am Post subject: Re: 504 engines and heads I am curious?? |
jeff can you email me when you get a minute. got a question for you. thanks robbie
email should be open |
| Back to top |
Posted: Mon Nov 12, 2012 11:42 am Post subject: Re: 504 engines and heads I am curious?? |
Plowboy, I couldnt get your email to work. Jeffgravert@msn.com or 308 940 0255. Later Jeff |
| Back to top |
Posted: Mon Nov 12, 2012 11:46 am Post subject: Re: 504 engines and heads I am curious?? |
| Back to top |
Posted: Mon Nov 12, 2012 12:21 pm Post subject: Re: 504 engines and heads I am curious?? |
Thanks for the info I was curious about that. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
