| Author |
Message |
Matt 49 TEA Australia Regular
Posted: Sat Nov 10, 2012 2:12 am Post subject: 1953 TEA20 technical question |
Hello all I am helping a friend rebuild a 1953 tea20 standard engine, 85mm bore, 12V. When we pulled it apart we discovered some items I have never seen before and I would like to know if anybody may know why
The first item was the rear main seal, instead of the rubber split seal that feeds into the groove of the block and main bearing cap it has a worm machined in the crank and 2 cast aluminium plates that exist in place of the rubber seal, it relies totally on rotation of the crankshaft and the worm rotation to prevent oil escaping. The 2 half plates also have spiral grooves cut in them
The second item is the timing chain, it has a tensioner made of stainless steel that keeps the loose side of the chain from flapping, it pivots on a pin that goes through to the engine block at one end and the other rests against the timing case
I have worked on lots of these engines and never seen it before, does anybody have the answer, maybee parts from a vangard car or a baler engine etc, thanks Matt. |
| Back to top |
2tractors Long Time User
Posted: Sat Nov 10, 2012 5:30 am Post subject: Re: 1953 TEA20 technical question |
I recently replaced the timing chain on a 35 standard gas with no tensioner and while chasing the cause of dropping oil pressure with new pump I removed the half moon rear bearing.Seems to me someone has modified yours.
| Back to top |
VTParts Guest
Posted: Sat Nov 10, 2012 5:55 am Post subject: Re: 1953 TEA20 technical question |
If you need parts for the TE 20 we will be parting one out that has the standard engine.
vermontventuresllc@gmail.com
802-782-2409 |
| Back to top |
Charles in Aus. Regular
Posted: Sat Nov 10, 2012 1:52 pm Post subject: Re: 1953 TEA20 technical question |
Matt , can you try to post a picture ? Sounds really strange! The tensioner is really odd, this could have come from a Vanguard as you suspect. Is the distributor different in any way? |
| Back to top |
Posted: Sun Nov 11, 2012 3:23 am Post subject: Re: 1953 TEA20 technical question |
Hello charles, I will go over to my mates place and photograph the parts, keep looking at this post mate, as I say I have worked on many of these and never seen before. The engine has been apart previously, it has pistons with both oil rings above the gudgeon pin which was the case for vangard car, ferguson had one oil ring at the bottom of the skirt, it also has a cylindrical oil pickup strainer attached directly to the pump. |
| Back to top |
Bob (Aust) Tractor Expert
Joined: 06 Sep 2007 Posts: 2209 Location: Queensland, Australia
Posted: Sun Nov 11, 2012 4:20 pm Post subject: Re: 1953 TEA20 technical question |
I am not sure what question you are asking about the timing chain, but the Standard engine does not have a timing chain tensioner. It has a guide only.
I'll see if I can find the photo I have inside the timing case.
Bob in Oz
'53 TEA20 |
| Back to top |
Posted: Mon Nov 12, 2012 3:17 am Post subject: Re: 1953 TEA20 technical question |
Here is the crankshaft and rear main seal area, note the spiral groove in the crank and the 2 aluminium plates in place of the rubber seal
| Back to top |
Posted: Mon Nov 12, 2012 3:27 am Post subject: Re: 1953 TEA20 technical question |
Hi Bob, here is the tensioner assembly, it is pivoted at one end by a pin through to the engine block and the other end rests against the inside of the timing cover, it is very well made, not by somebody with a pair of tinsnips etc and the extra hole in the timing cover appears factory, have you ever seen this?
| Back to top |
Posted: Mon Nov 12, 2012 3:36 am Post subject: Re: 1953 TEA20 technical question |
A better view of the sealing plates
| Back to top |
Posted: Mon Nov 12, 2012 3:46 am Post subject: Re: 1953 TEA20 technical question |
Here is the end view of the plates, all comments welcome, please let me know if you have seen this setup before, regards Matt.
| Back to top |
John(UK) Long Time User
Posted: Mon Nov 12, 2012 6:44 am Post subject: Re: 1953 TEA20 technical question |
I have heard of the scroll type rear crank seal but never seen one and it certainly isn't shown in the parts list. I suspect as you do that it is from the vanguard engine along with the crankshaft, which would fit the tractor block. The tensioner on the timing chain is home-made, on the tractor you just have the chain, there is no need for a tensioner, if the chain does wear then it should be changed. Usually chains have a good life and the Governor is what may fail first and when you tear the engine down to repair that, you will see the chain and change it. The chain should be changed anyway when repairing the Governor. Using a tensioner can allow the timing to be slightly out because of the wear in the chain, there is no allowance for this. The Camshaft has infinitely variable timing that needs to be set correctly as it isn't straight forward unless you know..PS. I have just looked at a Vanguard parts list and the Crank and the rear seal are as you describe, so it would appear that they are both from the Vanguard unit..John(UK)....fergusontractors@hotmail.com |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
