| Author |
Message |
BigTone Regular
Posted: Sat Nov 10, 2012 3:33 am Post subject: Radiator shroud |
I have an aftermarket radiator on my M and I have read bad things about them but not until i put $350 into refurbishing it, the steering shaft hole does not line up where is should requiring me to put 2 gaskets on one side and none on the other (my father in law had previously done the same thing and thats why it required so much welding). I have to put 2 gaskets on one side and 1 gasket on the other so it doesnt break apart from the vibrations but now the fan hits the shroud at the very bottem.
Can I cut 3 inches of the bottem of the shroud so the fan doesnt hit without compromising the way the fan/radiator work? thanks guys, ~Anthony |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18224 Location: St. Cloud, MN
Posted: Sat Nov 10, 2012 7:08 am Post subject: Re: Radiator shroud |
One additional option is to elongate the mount holes in the shroud and /or ad shims to move it down (that would keep it basically original, and complete at the bottom. The cutting is OK, in terms of function. Jim |
| Back to top |
David G Tractor Guru
Posted: Sat Nov 10, 2012 8:30 am Post subject: Re: Radiator shroud |
I had to ADJUST the mounting holes and cut a little on my H shroud to make it fit. Welcome to the world of chinese manufacturing. |
| Back to top |
KTWashburn Guest
Posted: Sat Nov 10, 2012 12:53 pm Post subject: Re: Radiator shroud |
Guess I lucked out. I put a Northern brand radiator on my H and had no fitment issues. |
| Back to top |
Jim Becker Tractor Expert
Posted: Sat Nov 10, 2012 1:43 pm Post subject: Re: Radiator shroud |
I've never had to deal with that problem and don't know if this suggestion is any good. However, my first thought is to take the radiator to a radiator shop and see if they could relocate the steering shaft hole. Why mess up several correct parts to make a misfit work? Better to at least try to fix the part with the problem. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
