| Author |
Message |
Baelee05 Regular
Posted: Sat Nov 10, 2012 5:43 am Post subject: John T and others..... Thanks for the help |
Thanks to everyone who chimed in with advice for my genny and VR problems with the old forklift and M this past week. The problem with the M was twofold. First, I had it wired incorrectly and second, the VR was set improperly from the shop I got it from. Basically both the forklift and M problems were caused by improperly set VRs from my gen shop. These guys are usually really good but they kind of let me down on these two things. Oh well. Just glad to have both issue resolved. Now onto other things! The clutch on this old M hasn"t been right since I got it so I think I am going to see about fabbing up some spilt stands and put a clutch and a rear engine seal in the old girl. It will be my first split see we will see how that goes! |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18238 Location: St. Cloud, MN
Posted: Sat Nov 10, 2012 7:03 am Post subject: Re: John T and others..... Thanks for the help |
Thanks, Good luck with the split. Making the stands so that their point of contact with the floor is at least 36 inches apart assists in keeping things upright. (important) allowing each side to have an inch of up down adjustability is also desirable. Jim |
| Back to top |
Smitholm Guest
Posted: Sat Nov 10, 2012 8:52 am Post subject: Re: John T and others..... Thanks for the help |
Um, not an expert in this area by any means, but I'm not at all sure you need a split to replace a clutch on an M. Super M, however, a different story I believe. |
| Back to top |
Baelee05 Regular
Posted: Sat Nov 10, 2012 9:48 am Post subject: Re: John T and others..... Thanks for the help |
Thank You. I am considering using someone else's idea for mounting trailer jacks to the side rails for jack stands. I thought I would then mount some outriggers of some kind further foward to assist in keeping the thing from tipping. Going to take some time and think about it before doing anything. |
| Back to top |
Posted: Sat Nov 10, 2012 9:51 am Post subject: Re: John T and others..... Thanks for the help |
The pressure plate and disk are replaceable without splitting. The geometry is a little tight, but very doable. Jim |
| Back to top |
Baelee05 Regular
Posted: Sat Nov 10, 2012 11:33 am Post subject: Re: John T and others..... Thanks for the help |
If I decide to go the trailer jack route for the split do yo think two 1000 lb jacks are sufficient? |
| Back to top |
Posted: Sat Nov 10, 2012 11:50 am Post subject: Re: John T and others..... Thanks for the help |
in lift yes in side to side and forward and back they would need diagonal bracing. Jim |
| Back to top |
JDnTN Regular
Posted: Sat Nov 10, 2012 7:11 pm Post subject: Re: John T and others..... Thanks for the help |
I had heard about the non-split/urban legend. How do you replace the clutch/pp without splitting? Thanks, Jon |
| Back to top |
Owen Aaland Tractor Expert
Joined: 14 Feb 2007 Posts: 2979 Location: Zumbrota MN
Posted: Sun Nov 11, 2012 1:08 am Post subject: Re: John T and others..... Thanks for the help |
| JDnTN wrote: | | (quoted from post at 23:11:44 11/10/12) I had heard about the non-split/urban legend. How do you replace the clutch/pp without splitting? Thanks, Jon |
About the only thing that may be a bit out of the ordinary in replacing the M clutch without splitting the tractor is that you remove every other PPA mounting blot and install them back into the pressure plate to compress the springs. Other than that it is a matter of removing the LiftAll pump, disconnecting and removing the drive shaft coupler,release the clutch pedal return spring, and remove the two bolts that hold the release bearing pilot tube to the clutch housing. At that point you can usually remove the drive shaft from the clutch disk. Some times you have to remove the other three bolts from the PPA to be able to slide the shaft out. Once the shaft is out the PPA and disk will come out. |
| Back to top |
Baelee05 Regular
Posted: Sun Nov 11, 2012 3:45 am Post subject: Re: John T and others..... Thanks for the help |
Thanks Owen. This one needs a rear seal too so I am going to go ahead and split it. This will also give me the experience of splitting one and allow me to get a better idea of how to do a clutch removal in the future without splitting. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
