Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
52 8N Electrical Partially Solved
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
equeen
PostPosted: Sat Nov 10, 2012 3:49 pm    Post subject: 52 8N Electrical Partially Solved Reply to specific post Reply with quote
Thanks to all who have helped regarding brother's 52 8N electrical problems. Special thanks to OLD for his "hot wire" suggestion.
Coil forward is now fine. Tractor starts well and runs fine - with electrical circuit/devices from coil forward. Problem was with the side post of distributor. I now have 3 sets of points and condensers in the trash from burning 'em up while trying to find and solve problem.
Tractor will not start when remove jumper and go back to all wiring and devices. Actually get a 6v reading input to coil. But tractor will not start unless "hot wire" as mentioned above.
Next step is to check out devices and wiring from coil input back - one at the time - to find the last, or at least one of the last, problems. Will begin Monday.
old
PostPosted: Sat Nov 10, 2012 5:23 pm    Post subject: Re: 52 8N Electrical Partially Solved Reply to specific post Reply with quote
Ok so it runs with a hot wire so next jumper the ignition switch and see if it runs that way. If it does bad switch if if does not then check the wire from the switch to the battery and ALL connections back to the battery
JMOR
PostPosted: Sat Nov 10, 2012 5:27 pm    Post subject: Re: 52 8N Electrical Partially Solved Reply to specific post Reply with quote
equeen wrote:
(quoted from post at 19:49:46 11/10/12) Thanks to all who have helped regarding brother's 52 8N electrical problems. Special thanks to OLD for his "hot wire" suggestion.
" I now have 3 sets of points and condensers in the trash from burning 'em up while trying to find and solve problem. "
Well, you can go dig those condensers out of the trash for sure as you did not "burn them up" & probably the points, too, as a short in the distributor feed through would have prevented the points from ever switching any load current.
equeen
PostPosted: Sun Nov 11, 2012 3:17 am    Post subject: Re: 52 8N Electrical Partially Solved Reply to specific post Reply with quote
"Well, you can go dig those condensers out of the trash for sure as you did not "burn them up" & probably the points, too, as a short in the distributor feed through would have prevented the points from ever switching any load current."
Please explain further, JMOR.
Are you saying, in effect, that the current would have stopped at the point of the short thus nothing downstream of that point would have been damaged? Hmmm? Plugs don't spark with such a short, thus no current to plugs. Hmm? Makes sense if I'm understanding you correctly.
Not sure that I want to mess with a currently operating system to see if they work; but may dig 'em out and put a question mark on the package???
JMOR
PostPosted: Sun Nov 11, 2012 5:54 am    Post subject: Re: 52 8N Electrical Partially Solved Reply to specific post Reply with quote
equeen wrote:
(quoted from post at 07:17:02 11/11/12) "Well, you can go dig those condensers out of the trash for sure as you did not "burn them up" & probably the points, too, as a short in the distributor feed through would have prevented the points from ever switching any load current."
Sounds like you got it.
old
PostPosted: Sun Nov 11, 2012 12:39 pm    Post subject: Re: 52 8N Electrical Partially Solved Reply to specific post Reply with quote
I almost never throw away any old parts. I have a Ben I throw them in so if I ever need something and do not have the time to go buy it I look in my old parts stash and most of the time can clean them up and get by for a long time
