Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4240 hydralic issue?
Post new topic    Yesterday's Tractors Forum Index -> John Deere
travz500
PostPosted: Sun Nov 11, 2012 5:30 am    Post subject: 4240 hydralic issue? Reply to specific post Reply with quote
i got a 81 4240 with 7200 hours and the hydralics are starting to whine some when gets warm and also the steering gets hard to turn when you have a bale on the front loader it wont turn like it used to have changed the filter and checked the sump screen and it was clean its a quad range the oil light never comes on. could this be the hydralic pump going bad? trying to determine whether to call the dealership to come up and look at it or take it to them
tim s
PostPosted: Sun Nov 11, 2012 5:42 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
Stick a gauge into a remote outlet and see what the standby pressure is, you may need to turn the stroke valve screw in a bit to increase the pressure up to the 2250 mark
travz500
PostPosted: Sun Nov 11, 2012 8:18 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
thanks Tim but I dont have a gauge sounds like I may just need to call the dealership
Tx Jim
PostPosted: Sun Nov 11, 2012 9:20 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
travz500 wrote:
(quoted from post at 12:18:54 11/11/12) thanks Tim but I dont have a gauge sounds like I may just need to call the dealership
It would be a lot cheaper to buy a gauge than have a dealer tech test the psi.
tim s
PostPosted: Sun Nov 11, 2012 9:22 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
You can pick up a good 5,000psi gauge for about $35 screw a fitting on it and you have one..dealer service call plus an hour or so $$$$,,if you were closer you could borrow mine I have 4 or 5 of them ,,loan out to the neighbors a lot...
travz500
PostPosted: Sun Nov 11, 2012 9:26 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
well ok i may just do that then is there a certain kind of gauge? like something tractor supply or orchelins would have? then just hook it up to the remotes in back?
thanks guys will do this week and try it out was afraid i may have a hydralic pump going out or something
Tx Jim
PostPosted: Sun Nov 11, 2012 9:29 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
Here's a gauge for $10.99
http://www.northerntool.com/shop/tools/product_48190_48190?cm_mmc=Aggregates-_-Shopzilla-_-Gauges>Filled%20Gauges-_-53617
DEEREMEYER1
PostPosted: Sun Nov 11, 2012 11:32 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
Just a regular 2 1/4 inch or so pressure gauge will work fine. Spend a few extra bucks and get a good liquid-filled one and use bushings to thread it into a standard SCV hose tip. Of course the preferred way to check standby pressure is at the priority valve on the RH side of the tractor with a jumper hose and DR quick-connect. The pressure adjustment is at the hydraulic pump itself, so if you're plugged in at the side, you can watch the gauge while you adjust the stroke-control valve instead of needing a helper to watch the gauge at the rear. If you do plug into an SCV, while you're at it, you can check to see if any of your SCVs are leaking up or down. Plug the gauge in like normal with the lever in neutral. If there is pressure at the gauge, the pressure side of the valve is leaking. Stroke the lever to put pressure to the gauge and then return the lever to neutral and if the pressure drops off rapidly, you have a return leak. You'll have to repeat the procedure for both couplers in each SCV since there are two pressure valves and two return valves per SCV.
travz500
PostPosted: Sun Nov 11, 2012 6:55 pm    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
so where is the screw i need to turn if its low? do I put the lever all the way forward and lock it up there to check pressure? and one last question why does this happen what makes it low? age and wear? abuse? people I got it from seem to be very meticulous about maintenace and have very nice equipment
Tx Jim
PostPosted: Mon Nov 12, 2012 4:20 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
Screw is on frt hyd pump on LH side in frt of radiator. Loosen jam nut (#36) and screw in (CCW)(#37). Wear on hyd components causes these adjustments to be needed. Hyd lever needs to moved in the correct direction depending on which plug-in in the breakaway coupler is utilized. Move lever as if operating a one-way cyl.
travz500
PostPosted: Mon Nov 12, 2012 7:46 pm    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
so if i am looking at this correctly its on the left
side and on the bottom am I correct? thanks for the
information SIR!!
Tx Jim
PostPosted: Tue Nov 13, 2012 3:32 am    Post subject: Re: 4240 hydralic issue? Reply to specific post Reply with quote
Yes you are correct LH side bottom,front of pump
