HYD LEVER CREEPS UP
RIP MAN
PostPosted: Sun Nov 11, 2012 6:39 am    Post subject: HYD LEVER CREEPS UP Reply to specific post Reply with quote
WHEN PLOWING THE HYD LEVER CREEPS UP TILL PLOW IS OUT OF THE GROUND. IS THERE ANY WAY TO TIGHTEN IT UP.IT HAS NEW FRICTION BLOCKS. TRACTOR IS A WD
Will Herring
PostPosted: Sun Nov 11, 2012 6:40 am    Post subject: Re: HYD LEVER CREEPS UP Reply to specific post Reply with quote
Same problem on my WD... Still haven't figured it out. Usually have to tie it in the down position when unused, and hold it down constantly when using an implement.
BushogPapa
PostPosted: Sun Nov 11, 2012 7:32 am    Post subject: Re: HYD LEVER CREEPS UP Reply to specific post Reply with quote
Keep those friction blocks Dry (NO Lubricant)..
New friction blocks are available..
Are the tension springs below the Quadrant in good shape..??
Those usually are the two places that cure the problem..
Ron..
Allis Dave
PostPosted: Mon Nov 12, 2012 6:00 am    Post subject: Re: HYD LEVER CREEPS UP Reply to specific post Reply with quote
Bushogpapa has the right idea. I had to hold my hyd lever the whole time I was plowing until I replaced the quadrant spring last winter. Now It stays wherever I put it.
EricB
PostPosted: Tue Nov 13, 2012 8:38 pm    Post subject: Re: HYD LEVER CREEPS UP Reply to specific post Reply with quote
When I had the problem on my WD I made an adjustment on the
control rod down by the frame. While frustrated over it I took
some time studying the movements controlling the valve function
on the pump, the tractor running and watching the clearances for
'lift', 'hold' and 'lower', loosened the set screw, adjusted and re-
tightened. I have never had the problem again.
