| Author |
Message |
bigboreG Regular
Joined: 07 Apr 2012 Posts: 432 Location: Lake View, IA
Posted: Sun Nov 11, 2012 7:02 am Post subject: G blowby update |
Thought id let you know what i have found so far. Checked compression, book calls for 65 i have 74 on both sides. So were good there. The breather is ok, but the oil pipe going to the tappet cover was plugged. This pumps oil to the tappets correct? Is this the only source of oil they get on a G as opposed to the A with its galley thru the block and head? Also can i just remove fork and pulley to check the drain back hole or does the reduction cover have to go as well? |
| Back to top |
MBdeere Regular
Posted: Sun Nov 11, 2012 7:44 am Post subject: Re: G blowby update |
You will be able to clean it by removal of the pulley only and of corse the stuff that needs to be removed to get the pulley off. |
| Back to top |
MBdeere Regular
Posted: Sun Nov 11, 2012 7:45 am Post subject: Re: G blowby update |
| Back to top |
BushogPapa Tractor Guru
Posted: Sun Nov 11, 2012 7:47 am Post subject: Re: G blowby update |
You can remove the Clutch and Fork to get to the drain-back groove..
Hope your rear tire is set out far enough...
I cannot give any information on the rocker oiling on a "G"..
Ron.. |
| Back to top |
old popper Long Time User
Posted: Sun Nov 11, 2012 8:49 am Post subject: Re: G blowby update |
If you need to move the wheel for clearance, I took the rim off the cast disk to gain room enough to take the pulley off mine. I don't know what it would take to move the hubs on the axles. |
| Back to top |
bigboreG Regular
Posted: Sun Nov 11, 2012 9:36 am Post subject: Re: G blowby update |
Thanks all. The wheels are all the way out, lucked out there! |
| Back to top |
bigboreG Regular
Posted: Sun Nov 11, 2012 10:19 am Post subject: Re: G blowby update |
Only drain back i see is at bottom of main case bout a 3/4 hole. Is there one on the pulley itself? |
| Back to top |
Posted: Sun Nov 11, 2012 12:59 pm Post subject: Re: G blowby update |
NO, it is a small hole in the bottom of the Groove on the "Seal(?)" that the "spiral" slings oil inside of..that IS all there is to this...!!
Ron.. |
| Back to top |
bigboreG Regular
Posted: Sun Nov 11, 2012 1:35 pm Post subject: Re: G blowby update |
Alright i found what i was looking for. Thanks Ron |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
