| Author |
Message |
WI Dave Regular
Posted: Sun Nov 11, 2012 7:26 am Post subject: H Trans Fluid Drain/Clean |
I finally got around to changing the trans fluid in my H. It took 4 hours to fill the 5 gal. bucket fron the rear drain, and I got about 1 gal. from the front drain plug, but had to scrape/pull the sludge out the whole time. The belt pulley drive is still off, and I can see there's still about an inch of sludge still in there. Should I put the plugs back in and dump a few gallons of diesel in it, let it sit a few days, then drain and flush with more diesel? |
| Back to top |
rustred Tractor Expert
Posted: Sun Nov 11, 2012 7:46 am Post subject: Re: H Trans Fluid Drain/Clean |
if it were mine i would dump in a 50/50 mix of hyd. oil and diesel and drive it around for awhile.diesel alone is not the best lubrication for differential or trans. |
| Back to top |
Posted: Sun Nov 11, 2012 7:53 am Post subject: Re: H Trans Fluid Drain/Clean |
instead of reinstalling belt pulley off and on. just get a piece of 1/8 flat metal and fab. a cover for it with a couple bolts, even a 1/4 " plywood is good enough.just to keep the oil from splashing all over. |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Sun Nov 11, 2012 8:29 am Post subject: Re: H Trans Fluid Drain/Clean |
Diesel or kerosense and driving around slowly for a little while with no load is the remedy I have seen recommended to clean out sludge.
Zach |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
