| Author |
Message |
Noah in IA Regular
Posted: Sun Nov 11, 2012 7:52 am Post subject: AC C piston ring orientation |
Hey guys,
Just a quick question here since my service manual makes no mention of it; do I need to position the piston rings in any specific manner (like an angular offset between ring gaps) before installing into the sleeves? Also, what specific surfaces do you coat with assembly lube before install? As I"ve mentioned before, I"m new to this engine/mechanic"n stuff so your help is much appreciated!
Thanks, |
| Back to top |
Orange fever New User
Posted: Sun Nov 11, 2012 9:57 am Post subject: Re: AC C piston ring orientation |
You don"t need to aline in an specific order. Just remember you never align them all in the same spot. This would cause blow by and oil cunsumption problems. What i do is offset the ring gap by 3rds or 180 degrees from one another. The oil ring scraper I place one at 10 o"clock above the wrist pin and the other at 4 o"clock below the wrist pin. There should also be instructions on which side of the ring faces up.
As for assembly lube i use whichever weight of oil I"m running in the crankcase for assembly. Set your rings in a bowl of oil before you place them on your pistons. Oil the gland that the rings are to be install in on the piston. oil the inside of your piston sleeves before placing your piston into them. oil the wrist pin and where the rod connects to the wrist pin. Need less to say just oil everything, no oil will cause damage when you start the engine. I even place a little oil on top of piston for more lubercation when starting. So with all this oil just make sure your deck is oil free and dry for your head gasket to seal. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50670 Location: Lake of the Ozarks area of MO
Posted: Sun Nov 11, 2012 12:29 pm Post subject: Re: AC C piston ring orientation |
When I do rings I always line them up 180 out. If you have a 3 ring piston you do the oil or bottom ring one way then the next up 180 out and then the next/top 180 out. You can always do them so they are 1/3 of the way around from each other |
| Back to top |
BushogPapa Tractor Guru
Posted: Sun Nov 11, 2012 12:46 pm Post subject: Re: AC C piston ring orientation |
I like to orient the end-gaps somewhat over opposite wrist-pin ends..staggering a rather small amount..
Ron.. |
| Back to top |
rustred Tractor Expert
Posted: Sun Nov 11, 2012 2:29 pm Post subject: Re: AC C piston ring orientation |
yep thats the way i do it. keeping the gaps towards wrist pin area and out of the major and minor thrust area of piston. |
| Back to top |
Noah in IA Regular
Posted: Sun Nov 11, 2012 5:07 pm Post subject: Re: AC C piston ring orientation |
thanks guys - that's the info i was looking for! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
