| Author |
Message |
blunted Regular
Posted: Sun Nov 11, 2012 9:53 am Post subject: thro out bearing |
on my super c, parts sent me a big bearing witch wiil not work with whats on there. its like a houseing with a grafite peice that hits the fingers. has two greese jirks, one for hollow area maybe for that peice to turn, and the other jirk looks like for the shaft to tranny. it breaks apart faily easy with hammer and chisel. is this some kind of a differant deal? thanks. |
| Back to top |
gene bender Tractor Guru
Posted: Sun Nov 11, 2012 9:59 am Post subject: Re: thro out bearing |
They sold you the wrong part. |
| Back to top |
blunted Regular
Posted: Sun Nov 11, 2012 10:10 am Post subject: Re: thro out bearing |
when you look at pics in parts books and one on here , thay show what i got from them. im hopen there are two styles. thanks |
| Back to top |
Fritz Maurer Long Time User
Posted: Sun Nov 11, 2012 10:12 am Post subject: Re: thro out bearing |
The graphite piece does not turn. The clutch fingers ride right on it. Why are you hitting it with a hammer? If a piece is broken where the fingers ride, it is ruined. |
| Back to top |
blunted Regular
Posted: Sun Nov 11, 2012 10:32 am Post subject: Re: thro out bearing |
ok, so it is supose to turn? and yes i ruined it. it didnt turn in the houseing, thats why i tryid hitting it out and fineing it was like cyristelized. can i change it to the other style, or do i need to find that same thing? thanks |
| Back to top |
Posted: Sun Nov 11, 2012 2:07 pm Post subject: Re: thro out bearing |
No, the graphite ring is stationary. The fingers slide on it's surface; graphite is self-lubricating. I didn't know that you could even get those old bearings anymore. Don't feel bad though. I did the exact same thing in '81... only I did it to the old one. I don't remember any fittings at all on mine, maybe one to lube where it slides on the sleeve. Either bearing will fit, but I'd prefer the graphite, just because it's weird. |
| Back to top |
blunted Regular
Posted: Sun Nov 11, 2012 2:13 pm Post subject: Re: thro out bearing |
its the old one that i ruined. it did have a pretty good groove on the face frome the fingers. i guess il have to find the other style. thats funny, this is a 53 super c, and my 39 a has the other style. go figure. junk yard ya think? thanks |
| Back to top |
Posted: Sun Nov 11, 2012 2:26 pm Post subject: Re: thro out bearing |
Mine is a '52, it had the same bearing. My dealer gave me a ball bearing, I'm guessing your '39 had the clutch changed at some point. |
| Back to top |
blunted Regular
Posted: Sun Nov 11, 2012 2:57 pm Post subject: Re: thro out bearing |
very well could have. il have to see if i can find the new style. just thinking tho, maybe a guy could figure making one himself, to put the new style bearing on. ever heard of that? |
| Back to top |
pete 23 Tractor Expert
Posted: Sun Nov 11, 2012 5:13 pm Post subject: Re: thro out bearing |
Always changed them to regular thrust ball throw out bearing and sleeve when I had them apart as they were always grooved and would never fit a new finger very well. |
| Back to top |
blunted Regular
Posted: Sun Nov 11, 2012 8:42 pm Post subject: Re: thro out bearing |
thanks, pete, and every one too. do you know where to get that for sure? thanks |
| Back to top |
Posted: Mon Nov 12, 2012 5:23 am Post subject: Re: thro out bearing |
If there is enough metal where the block slides on the sleeve... sure, why not? All you need is a lathe and a four-jaw chuck. That's a lot of trouble, though. The ball bearing style that hard to find? |
| Back to top |
Posted: Mon Nov 12, 2012 6:18 pm Post subject: Re: thro out bearing |
I was the dealer mechanic so I just told the parts man to get me one. Now days, I would check their price and availability at dealer and then make a decision. |
| Back to top |
