| Author |
Message |
Will Herring Long Time User
Posted: Sun Nov 11, 2012 1:16 pm Post subject: What do you guys call a "ground level" implement l |
Grandpa always called it a "steel road drag"... Can't remember it being used more than once or twice (usually just to move it out of the way). Some sort of cutting blade underneath. Works pretty good for leveling out messes from stuff like dumped dirt from a loader bucket in a hole [just tried it out for that awhile back]... No idea what it is truly called though.
| Back to top |
hardscrabble Regular
Posted: Sun Nov 11, 2012 2:44 pm Post subject: Re: What do you guys call a |
"Road drag is what they called them around here too. In the old days, before the county maintained roads, every farmer had a road drag, and took care of his own roads. Now they are a specialty item, used mainly for driveways. |
| Back to top |
Posted: Sun Nov 11, 2012 2:50 pm Post subject: Re: What do you guys call a |
| hardscrabble wrote: | | (quoted from post at 18:44:36 11/11/12) "Road drag is what they called them around here too. In the old days, before the county maintained roads, every farmer had a road drag, and took care of his own roads. Now they are a specialty item, used mainly for driveways. |
Are they of any use in fields or anything? |
| Back to top |
flying belgian Tractor Expert
Posted: Sun Nov 11, 2012 3:56 pm Post subject: Re: What do you guys call a |
Yep. We called it a road drag. |
| Back to top |
paul Tractor Guru
Posted: Sun Nov 11, 2012 5:40 pm Post subject: Re: What do you guys call a |
In general in the field there is too much vegitation causing plug-ups and they don't work well on a long haul. Could be useful to fix up an issue of some sort, but not as a general cover the whole field sort of thing?
--->Paul |
| Back to top |
BCnT Tractor Expert
Posted: Sun Nov 11, 2012 6:42 pm Post subject: Re: What do you guys call a |
i've never seen a drag with plate over it...mine is 5 pieces of railroad track welded inside a pipe frame.
does that one have multiple drag edges underneath? |
| Back to top |
Posted: Sun Nov 11, 2012 8:01 pm Post subject: Re: What do you guys call a |
Never have managed to look underneath it, but I know there is at least some sort of cutting blade in the middle of it... Or so I was told. |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9502 Location: Wapakoneta, Ohio
Posted: Mon Nov 12, 2012 4:42 am Post subject: Re: What do you guys call a |
Sure wish we could see the underside, never heard of such a thing. Grew up with gravel roads and a lot still in area I do a lot of traveling in. |
| Back to top |
BushogPapa Tractor Guru
Posted: Mon Nov 12, 2012 7:46 am Post subject: Re: What do you guys call a |
Could not use it in any damp soil or it would just pack full and do nothing..
Must have been for a dirt/gravel road, or limited use leveling..
Ron.. |
| Back to top |
ihman73 Regular
Posted: Mon Nov 12, 2012 8:41 am Post subject: Re: What do you guys call a |
We use ours to level up cattle drylots and field roads. Used to use behind a disk before we had a field cultivator back in the plow everything days. |
| Back to top |
TomA Regular
Posted: Mon Nov 12, 2012 12:23 pm Post subject: Re: What do you guys call a |
I think it a weeder for summer fallow ground.
When a flush of weeds comes up and they are small
it is pulled over the ground and the knife cuts off
the weeds just below the surface and it leaves the
ground nice and smooth so it will hold moisture. If
that is what it is it has a name, I just cant remember
it. |
| Back to top |
Nebraska Cowman Tractor Guru
Joined: 10 Aug 2003 Posts: 10814 Location: Wellfleet NE
Posted: Mon Nov 12, 2012 4:30 pm Post subject: Re: What do you guys call a |
Yes, The county still uses road Drags here. They have a hoist arrangement on the back of the Patrol to carry it in transport. Dad talked about the King Drag. I suppose "King" was a brand name. |
| Back to top |
Posted: Mon Nov 12, 2012 4:35 pm Post subject: Re: What do you guys call a |
After I posted I got curious and googled it.
http://en.wikipedia.org/wiki/King_road_drag
King drag
| Back to top |
Ol' Gimpy Regular
Posted: Mon Nov 12, 2012 5:02 pm Post subject: Re: What do you guys call a |
My late father built similar units using oak 6x6"s,three of them boxed in.Always called it a "Slab".Used it mostly to level plowed sod,pulled in the direction of the plow.Also helped level fields,and could put rocks on it too.One of my first jobs-"Slabin". |
| Back to top |
Posted: Mon Nov 12, 2012 6:46 pm Post subject: Re: What do you guys call a |
| TomA wrote: | (quoted from post at 16:23:22 11/12/12) I think it a weeder for summer fallow ground.
it. |
An older gentleman from the area told me this same thing as well, but I cannot for the life of me remember when/how it was used (ie. right after discing, or right after planting, or what). |
| Back to top |
