53 Jube no spark update
William Fissell
PostPosted: Sun Nov 11, 2012 3:01 pm    Post subject: 53 Jube no spark update Reply to specific post Reply with quote
For those who didn't read the prior thread: 6V,
pos ground, suddenly no spark after dead battery.
Following sounder's advice:
jumper from neg of battery to batt side of coil.
Spark plug connected directly to wire from coil
(no dizzy) and body of spark plug grounded via
jumper cables to (+) on battery.
Grounding the dizzy side of the coil -> weak blue
spark on the spark plug then fat orange spark when
I unground the coil. What I'd expect, except wimpy
spark.
Interestingly, if I do it again, a moment later ->
no spark at all on the spark plug. but I still get
the fat orange spark. If I wait for 5-10 min, I
get the weak blue spark again.
I assume I should be able to just zap zap zap zap
zap until I get bored of it, no?
This I think makes the coil the suspect.
However... will get a new ignition switch anyway
as its likely original and likely to be flaky.
anything else I am missing?
old
PostPosted: Sun Nov 11, 2012 4:05 pm    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
Sounds like and from what you typed here that your way over thinking a very simple ignition system. You have a battery which in turns powers the system by way of a switch and a wire from that going to the coil which then in turn is hooked to the points which when they open cause a spark to the plugs. A simple hot wire from the ignition side of the battery as in none ground side to the ignition side of the coil as in non- point side of the coil will tell you if the problem is in the distributor or the system back to the battery including the switch
William Fissell
PostPosted: Sun Nov 11, 2012 5:30 pm    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
Thanks, old- I did that - no spark
grounded the points side of the coil for a second- weak blue spark. did it again. no spark.
souNdguy
PostPosted: Mon Nov 12, 2012 7:04 am    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
if you have hot wired the primary of the coil, disconnected the coil from the dizzy and are grounding it's primary on and off.. and it's not throwing a spark.. I'd swap a coil from another machine and check
William Fissell
PostPosted: Mon Nov 12, 2012 7:12 am    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
yup.
that's where I am at.
Will do.
oldcase
PostPosted: Mon Nov 12, 2012 8:50 am    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
Don't forget about the ballast resister between the ignition switch and the coil. They are notorious for causing the no spark condition you describe.
JEK1
PostPosted: Mon Nov 12, 2012 9:00 am    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
That very same thing was happening to my 8n side mount distributor tractor. All of the electrical checks were OK.
It turned out that that terminal stud located on the exterior of the distributor where the wire is hooked from the coil was shorting to ground. When the terminal nut gets torqued, the insulation gets sheared. The insulation is made from gasket like material. I made one from plastic from the top of an aerosol can.
The tractor now starts Oh so much better with a rich spark.
souNdguy
PostPosted: Mon Nov 12, 2012 11:26 am    Post subject: Re: 53 Jube no spark update Reply to specific post Reply with quote
there is no ballast resistor on a 6v/53 setup
