| Author |
Message |
Heat Houser Long Time User
Posted: Sun Nov 11, 2012 4:39 pm Post subject: 820 2 cyl Diesel |
A friend of mine is trying to pull the head off of an 820, has all the nuts off of the studs, hammered, yanked and pushed and it won't break loose. The last time I ever messed with a 2 cyl diesel was at a junk yard when I was a youth. Were there bolts up from the bottom, thru the frame, or does he simply have to get "physical" with it? |
| Back to top |
F-I-T Tractor Guru
Joined: 27 Feb 2002 Posts: 8447 Location: United States
Posted: Sun Nov 11, 2012 5:00 pm Post subject: Re: 820 2 cyl Diesel |
| Heat Houser wrote: | | (quoted from post at 17:39:13 11/11/12) A friend of mine is trying to pull the head off of an 820, has all the nuts off of the studs, hammered, yanked and pushed and it won't break loose. The last time I ever messed with a 2 cyl diesel was at a junk yard when I was a youth. Were there bolts up from the bottom, thru the frame, or does he simply have to get "physical" with it? |
10 total nuts, 8 short, two tall. Most times you need to bump the manifold with a wood fence post, and it will slowly jiggle off. A testimony to the lead washers packing down and around the studs. He can also download the free parts book at jdparts.com and see for himself. |
| Back to top |
Haet Houser Guest
Posted: Sun Nov 11, 2012 5:19 pm Post subject: Re: 820 2 cyl Diesel |
Thanks F-I-T.
Have a retired aircraft A&P helping one of his buddys with his 820. He called me asking, I couldn't remember, so I then posted his question. |
| Back to top |
Kent Petersen Long Time User
Posted: Sun Nov 11, 2012 5:20 pm Post subject: Re: 820 2 cyl Diesel |
dont forget the four nuts and lock washers inside the inj pump area remove cover over the pumps and look there are four studs that face into the block |
| Back to top |
F-I-T Tractor Guru
Posted: Sun Nov 11, 2012 5:32 pm Post subject: Re: 820 2 cyl Diesel |
| Kent Petersen wrote: | | (quoted from post at 18:20:36 11/11/12) dont forget the four nuts and lock washers inside the inj pump area remove cover over the pumps and look there are four studs that face into the block |
Yup, there you go! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
