Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
G-vi rear gears
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline
Albert Goerzen
PostPosted: Sun Nov 11, 2012 9:09 pm    Post subject: G-vi rear gears Reply to specific post Reply with quote
I was wondering if there are any other slower rear gears for a G6? It seems that 1st gear is too fast for alot of things, (like beating a 660 ihc in a tractor pull).
mightymolinekid
PostPosted: Wed Nov 14, 2012 4:18 pm    Post subject: Re: G-vi rear gears Reply to specific post Reply with quote
The problem may not be in the rear, it might be up front under the hood. If your engine is stock I would concentrate on making more HP. Is it diesel or LP? How about rear tires as a way to slow it down? If you're running the 18.4/34, maybe you could go down to a 16.9/34? The real early U had slower gears I think but I don't know how they'd swap into a GVI.
Albert Goerzen
PostPosted: Thu Nov 15, 2012 10:00 pm    Post subject: Re: G-vi rear gears Reply to specific post Reply with quote
You make a good point. My G6 is stock, except for the fuel screw is all the way out. It makes rated power at 100 rpm over spec. (78hp @ 1500 RPM). I thot that was pretty good at 3500 ft above sea level. The 660 could make a little more but his big advantage is his super slow first gear. We are equals if he uses 2nd. If traction is not good on a given day it can go either way. As for tires, we both run 18-34s, he runs R1W radials but i dont see the advantage. I do have a set of 16.9s on a GTB that i could try quite easily. I run new Firestone 23degree on everything.
moresmoke
PostPosted: Fri Nov 16, 2012 3:19 am    Post subject: Re: G-vi rear gears Reply to specific post Reply with quote
Which fuel pump do you have? If its a roosamaster, there is more than one fuel screw. The real one is down inside the pump.
Albert Goerzen
PostPosted: Sat Nov 17, 2012 8:59 pm    Post subject: Re: G-vi rear gears Reply to specific post Reply with quote
Its got the American Bosch PSB6A-80D. When you take off the top cover and the fuel shut off cover, I moved the stop up far enough that the lever on the shut off cover side is right against the post.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
