| Author |
Message |
farmallday Regular
Posted: Mon Nov 12, 2012 3:56 am Post subject: sm?? |
Looked a a M on craiges list it is a SM what is the S?? |
| Back to top |
IaGary
Joined: 14 Jun 2007 Posts: 7238 Location: North Liberty Iowa
Posted: Mon Nov 12, 2012 4:06 am Post subject: Re: sm?? |
From 1952 thru 1953 or 54 Super M's were built. They made a few changes to the M and called it a Super M.
So the S stands for Super.
Gary |
| Back to top |
farmallday Regular
Posted: Mon Nov 12, 2012 4:52 am Post subject: Re: sm?? |
so the super M is stamped SM on the searial tag? |
| Back to top |
mkirsch Tractor Guru
Posted: Mon Nov 12, 2012 5:10 am Post subject: Re: sm?? |
The SM is silk-screened on the tag, not stamped, but basically, yes to your question.
A regular M will have FBK on the serial tag. |
| Back to top |
Bob M Tractor Guru
Posted: Mon Nov 12, 2012 7:03 am Post subject: Re: sm?? |
A true Super M serial number will begin with either SM or L depending in which plant it was assembled (SM = Rockford; L = Louisville).
Bear in mind there are MANY regular M tractors around with Super M decals applied. Buyer beware! |
| Back to top |
D Slater Tractor Expert
Posted: Mon Nov 12, 2012 7:58 am Post subject: Re: sm?? |
Letters SM will be near the top left corner looking at the serial tag the way you would read it on a super M. Serial number and its prefix and sufix letters will be on a different level than the SM or SMD if a diesel. If a S follows the serial number on the same level it may be a super MTA. LP tractors can also have letters. |
| Back to top |
farmallday Regular
Posted: Mon Nov 12, 2012 9:03 am Post subject: Re: sm?? |
buyer beware is correct. But in this case it is oppasit. I beleave it has a SM serail # but regular M decals!! |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5369 Location: SE Wisconsin
Posted: Mon Nov 12, 2012 9:44 am Post subject: Re: sm?? |
| Bob M wrote: | (quoted from post at 08:03:15 11/12/12) A true Super M serial number will begin with either SM or L depending in which plant it was assembled (SM = Rockford; L = Louisville).
Rockford??? Isn't it Rock Island? |
| Back to top |
Bob M Tractor Guru
Posted: Mon Nov 12, 2012 9:51 am Post subject: Re: sm?? |
Oops - I meant Rock Island! (Hadn't had my coffee yet when I typed that...) |
| Back to top |
Fullers Farmalls Long Time User
Posted: Mon Nov 12, 2012 11:17 am Post subject: Re: sm?? |
Here is my Super M tag. Just to give a little view of what they look like with the SM on them.
| Back to top |
farmallday Regular
Posted: Mon Nov 12, 2012 11:21 am Post subject: Re: sm?? |
Thanks guys!! |
| Back to top |
Posted: Mon Nov 12, 2012 7:31 pm Post subject: Re: sm?? |
| Bob M wrote: | | (quoted from post at 10:51:25 11/12/12) Oops - I meant Rock Island! (Hadn't had my coffee yet when I typed that...) |
Same state...  |
| Back to top |
