Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
63 JD 3010 - rear axle slipped out?
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Tom bonehead
PostPosted: Mon Nov 12, 2012 10:57 am    Post subject: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
With both rear wheels in the air, left side wheel engages and rotates through all gears - right side is free spinning (always). A quick measurement from sidewall to frame shows the right side is 1.25" further away from frame than left side. The right wheel axle seal also shows considerable (fresh) leak of fluid.
This all leads me to believe, perhaps a snap-ring let go and the axle slid out of differential, disengaging the planetary gears? Comments? Thoughts? Any idea how i can tell if those rear tires are filled with anything?
tim s
PostPosted: Mon Nov 12, 2012 11:01 am    Post subject: Re: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
No snap ring,,the keeper and axle bolt backed away, probably because a bearing is bad, or the outer spacer got hammered up and let the bearing slack. The final drive will need to be pulled.
Tom Bonehead
PostPosted: Mon Nov 12, 2012 11:10 am    Post subject: Re: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
When i put a wrench on the two retainer ring-wheel bolts, they were loose. Finger-tight
830 man
PostPosted: Mon Nov 12, 2012 1:22 pm    Post subject: Re: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
Rotate the valve stem to the bottom and push it in. If there is anything in there you will know it.
2520-4010
PostPosted: Mon Nov 12, 2012 1:23 pm    Post subject: Re: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
Turn wheel so that the valvestem is low as it will go.......depress valvestem and check for liquid. ??
tim s
PostPosted: Mon Nov 12, 2012 2:58 pm    Post subject: Re: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
If your talking about the two pusher bolts they should be loose, you can pull and service the final drive with the wheel on. Use a floor crane and jack up the wheel till it will let the floor crane legs under then set it down on the crane legs as a dolly,drop a chain down from the mast ans hook to the axle housing..
Tom Bonehead
PostPosted: Tue Nov 13, 2012 12:56 pm    Post subject: Re: 63 JD 3010 - rear axle slipped out? Reply to specific post Reply with quote
great post! Thanks everyone! wish me luck
