| Author |
Message |
FactoryFarmer Long Time User
Posted: Mon Nov 12, 2012 3:30 pm Post subject: UPDATE: 37 A carb problems |
Finally got the carb figured out thanks to everyone who threw in advice (can't remember who but you know who you are)
Anyway, took the carb apart and everything seemed to check out. The one thing that someone mentioned is not having enough pressure pushing the fuel into the carb.
Well, I think that was the issue. After I got everything put back together with the fuel tank, new sediment bowl, etc. put on we pulled it maybe 5 feet and it popped right off and ran great! However it labors like its pulling a 5 bottom plow and the timing is way off. There is way to much advance in it. I think the guy who rebuilt the mag has the lag angle adjusted way off.
Thats a simple fix really, no big deal.
| Back to top |
gtx1967jewison Tractor Expert
Posted: Mon Nov 12, 2012 4:26 pm Post subject: Re: UPDATE: 37 A carb problems |
Looks to me like its firing LATE (retarded) as evidenced in
both pictures. Rotate the mag counter clockwise until your
AT the mark. To do this, have the engine OFF, put the mark
on the line, then rotate the mag SLOWLY back until it fires.
Now tighten it in place. That's it on a hand crank tractor, the
run timing is mechanical advance in the mag. |
| Back to top |
Posted: Mon Nov 12, 2012 5:39 pm Post subject: Re: UPDATE: 37 A carb problems |
Last edited by FactoryFarmer on Mon Nov 12, 2012 8:35 pm; edited 1 time in total |
| Back to top |
greenmech Long Time User
Posted: Mon Nov 12, 2012 6:55 pm Post subject: Re: UPDATE: 37 A carb problems |
I have to disagree with gtx. If you are firing before the marks on the flywheel and case cross,you are to far advanced. Ron Mn. |
| Back to top |
Pete in MD Long Time User
Joined: 09 Feb 2006 Posts: 890 Location: Millersville, MD
Posted: Mon Nov 12, 2012 7:40 pm Post subject: Re: UPDATE: 37 A carb problems |
Looks to me like the plug wires need to be reversed at the mag. |
| Back to top |
Posted: Mon Nov 12, 2012 8:20 pm Post subject: Re: UPDATE: 37 A carb problems |
| Pete in MD wrote: | | (quoted from post at 20:40:54 11/12/12) Looks to me like the plug wires need to be reversed at the mag. |
Almost every single tractor I have ever had with a mag have shown up here with the left plug hooked to the bottom. |
| Back to top |
Posted: Mon Nov 12, 2012 8:22 pm Post subject: Re: UPDATE: 37 A carb problems |
| greenmech wrote: | | (quoted from post at 19:55:34 11/12/12) I have to disagree with gtx. If you are firing before the marks on the flywheel and case cross,you are to far advanced. Ron Mn. |
Thank you Ron, I knew I wasn't going crazy. |
| Back to top |
Posted: Tue Nov 13, 2012 6:01 am Post subject: Re: UPDATE: 37 A carb problems |
The #1,flywheel side plug should be wired to the upper tower on the mag. |
| Back to top |
Posted: Tue Nov 13, 2012 6:28 am Post subject: Re: UPDATE: 37 A carb problems |
You are correct- it looked like the right side of picture was the front of tractor when I looked at it  |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
