Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
F 20 want start
Daninsc
PostPosted: Mon Nov 12, 2012 6:41 pm    Post subject: F 20 want start Reply to specific post Reply with quote
I'm still working on this project, I put head back on, adjusted valves, rebuilt carb, checked timing, tried to pull it off, seems like no fuel getting to cylinders. Made sure all passages were clear in carb. I think timing is good, I'm getting good spark. What else can cause this?
Kenneth R Ohnstad
PostPosted: Mon Nov 12, 2012 7:14 pm    Post subject: Re: F 20 want start Reply to specific post Reply with quote
Is gas turned on?
I don't say this to be an a$$hole...it comes from experience.
good luck
k
36F30
PostPosted: Mon Nov 12, 2012 7:39 pm    Post subject: Re: F 20 want start Reply to specific post Reply with quote
Do you have primer cups? are they closed? have they been removed and the holes in the head plugged? Any air leaks and she wont start.
If the primers are there and functional, fill them up and then open them and re-close them, puts gas right into the cylinders. If you don't get it to pop, then you have other problems.
rustred
PostPosted: Mon Nov 12, 2012 8:31 pm    Post subject: Re: F 20 want start Reply to specific post Reply with quote
you have to know if timing is right on otherwise thinking it is is not an answer. that is most likely your problem.
El Toro
PostPosted: Tue Nov 13, 2012 4:13 am    Post subject: Re: F 20 want start Reply to specific post Reply with quote
Hold your hand over the throat of the carburetor while a helper cranks over the engine. Should have good suction. Low suction means low intake manifold vacuum. You need good suction to pull that fuel into the engine. Make sure your valves have enough clearance. Hal
Daninsc
PostPosted: Tue Nov 13, 2012 4:36 am    Post subject: Re: F 20 want start Reply to specific post Reply with quote
The Pointer on the button it's dead on number one, I made sure its got fuel in the bowl, and I'll check the compression, tanks a lot everyone.
JRSutton
PostPosted: Tue Nov 13, 2012 4:54 am    Post subject: Re: F 20 want start Reply to specific post Reply with quote
You probably know this, but since it wasn't mentioned, make sure it's firing at tdc on #1 on the COMPRESSION stroke, not the exhaust stroke.
F-Dean
PostPosted: Tue Nov 13, 2012 5:22 am    Post subject: Re: F 20 want start Reply to specific post Reply with quote
Use a twisted belt to turn engine over and then go thru the ideas suggested by others.
F-Dean
PostPosted: Tue Nov 13, 2012 6:56 am    Post subject: Re: F 20 want start Reply to specific post Reply with quote
I've had the same experience!
slowfolk
PostPosted: Tue Nov 13, 2012 7:12 am    Post subject: Re: F 20 want start Reply to specific post Reply with quote
Can you hear the magneto snap when cranking engine.
rhtx55
PostPosted: Tue Nov 13, 2012 4:49 pm    Post subject: Re: F 20 want start Reply to specific post Reply with quote
As suggested use a flat belt to turn your engine over from another tractor, or try pull starting with another tractor.
They tend to be picky on starting with the crank on a fresh rebuild, usually pop right off after 15-20 ft of pulling ......if everything is set right.
