| Author |
Message |
swissman New User
Posted: Tue Nov 13, 2012 10:41 am Post subject: JD 146 loader |
I have a 146 jd loader(with mounting brackets) and was trying to get info on what tractors this could be used on.I believe it came off a 2030 utility.Any help would be appreciated. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13482 Location: Coyote Flats,Tx
Posted: Tue Nov 13, 2012 11:54 am Post subject: Re: JD 146 loader |
It should fit all JD 4 cyl utility tractors built in Dubuque/Mannheim factories. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23708 Location: in front of computer
Posted: Tue Nov 13, 2012 12:04 pm Post subject: Re: JD 146 loader |
There were both Waterloo and Dubuque/Mannheim frame mounts for the same 146 loader.
Info is on the JD web site parts list.
The hydraulic connections on a Dubuque/Mannheim have to be correct or the loader operates slow and with noisy shudders. |
| Back to top |
Dave H Long Time User
Posted: Tue Nov 13, 2012 3:00 pm Post subject: Re: JD 146 loader |
I swear my nieghbor has one mounted on a 4040. |
| Back to top |
4020_1966 Regular
Posted: Tue Nov 13, 2012 5:22 pm Post subject: Re: JD 146 loader |
My uncle has a 146 on a 4020, its just a 1 cylander version of the 148. |
| Back to top |
hover New User
Posted: Wed Nov 14, 2012 12:33 am Post subject: Re: JD 146 loader |
I have a 146 loader on a 2440 the 2030 is the same tracter one model older |
| Back to top |
woodbutcher Long Time User
Posted: Wed Nov 14, 2012 3:45 am Post subject: Re: JD 146 loader |
Hey, B&D, I think my 2040 has a 148 on it. All the decals have been scraped off. On a cold start-up, the fel shudders when I raise it. What are the proper connections you refer to?
Butch |
| Back to top |
Tx Jim Tractor Guru
Posted: Wed Nov 14, 2012 3:54 am Post subject: Re: JD 146 loader |
| buickanddeere wrote: | | (quoted from post at 16:04:16 11/13/12) There were both Waterloo and Dubuque/Mannheim frame mounts for the same 146 loader. Info is on the JD web site parts list.. |
Glen
Could you please post the page number that a Waterloo tractor is referred to in the 146 PC??????????? I saw no place that Waterloo was mentioned. These are the footnotes on the bottom of a mounting listing.
(A) With roll guard(B) without roll guard
(C) Tractor with sound guard body(D) Tractor without sound guard body(E) With heavy duty axle
(F) These frames fit all 4 cylinder tractors except sound-guard body
This is definitely not Waterloo 28 - Tractor to Loader Control Valve ( - 027000)
And neither is this.29 - Tractor to Loader Control Valve (027001 - )
| Back to top |
Tx Jim Tractor Guru
Posted: Wed Nov 14, 2012 3:57 am Post subject: Re: JD 146 loader |
| 4020_1966 wrote: | | (quoted from post at 21:22:16 11/13/12) My uncle has a 146 on a 4020, its just a 1 cylander version of the 148. |
146 had 2 bucket cylinders but a 48 had 1 bucket cyl. |
| Back to top |
Posted: Wed Nov 14, 2012 4:41 am Post subject: Re: JD 146 loader |
I'll take a look tonight but would be surprised if there was not
both Waterloo and Mannheim/Dubuque mounts for the 146.
Just about every other loader shared mounts. |
| Back to top |
buickandeere Regular
Posted: Wed Nov 14, 2012 4:48 am Post subject: Re: JD 146 loader |
Loader control valve oil supply needs to be T'd into the rockshaft/SCV supply line.
Loader return oil must be returned to a ported transmission oil filter cover.
Otherwise the SCV's will be tied up and not available for use. Worse the front oil pump will be starved for supply oil which causes cavitation.
The loader will operate faster and smoother when properly connected. |
| Back to top |
Tx Jim Tractor Guru
Posted: Wed Nov 14, 2012 5:39 am Post subject: Re: JD 146 loader |
| buickanddeere wrote: | (quoted from post at 08:41:51 11/14/12) I'll take a look tonight but would be surprised if there was not
Loader that JD engineers deemed to be constructed heavy enough for hp had mounts for both Waterloo and utility tractors but NOT ALL loaders were built that way. |
| Back to top |
Posted: Wed Nov 14, 2012 12:39 pm Post subject: Re: JD 146 loader |
Thanks. |
| Back to top |
Posted: Wed Nov 14, 2012 7:55 pm Post subject: Re: JD 146 loader |
Took some looking but.........
The 148 loader uses the same mast PN # AW16036
The model 148 loader mounts to Waterloo tractors
with frame #'s AW16346 and AW16347 |
| Back to top |
Tx Jim Tractor Guru
Posted: Thu Nov 15, 2012 3:43 am Post subject: Re: JD 146 loader |
| buickanddeere wrote: | (quoted from post at 23:55:22 11/14/12) Took some looking but.........
That mast # AW16036 also fits a 145 loader BUT that doesn't indicate that JD engineers intended or designed the ""frame mounts on a 145/146 loader"" to work on a Waterloo rowcrop tractor. |
| Back to top |
