What to do????
Eldo case
PostPosted: Tue Nov 13, 2012 10:43 am    Post subject: What to do???? Reply to specific post Reply with quote
I have a 211b case tractor that is smoking very bad. I put in a set of rings years ago. I am thinking about a complete rebuild and can't decide on what sleeve set to use. The 126 cid set is almost impossible to find and just almost as high. I have been thinking about having the block bored for the 148 sleeves but that is not stock for a 200b but will be cheaper in the long run. Just don't know what to do? Open to your all suggestions. Thanks!
1031D
PostPosted: Tue Nov 13, 2012 11:08 am    Post subject: Re: What to do???? Reply to specific post Reply with quote
Nobody will tear your engine apart to nit pick the originality of it. Another option is to have your sleeves sleeved and reuse the old pistons with new rings, done that too.
Adirondack case guy
PostPosted: Tue Nov 13, 2012 3:03 pm    Post subject: Re: What to do???? Reply to specific post Reply with quote
Eldo,
Make it a bear in sheep clothing. I don't see a problem making it a 300B under a 200B hood. The trannies are the same, so no issues there.
Loren
JPFL
PostPosted: Tue Nov 13, 2012 5:32 pm    Post subject: Re: What to do???? Reply to specific post Reply with quote
Hi, I have a few good used parts for a 211b should you need something give me a call. Thanks Jim --No-Advertising-in-Forums
C. Amick
PostPosted: Tue Nov 13, 2012 8:22 pm    Post subject: Re: What to do???? Reply to specific post Reply with quote
Won't the VAC engine rebuild kit work in that engine? I think they even sell them on this web site?
Eldo case
PostPosted: Wed Nov 14, 2012 5:43 am    Post subject: Re: What to do???? Reply to specific post Reply with quote
No the sleeve is like the 148 at the top and smaller at the bottom where the O-rings are.
