8n valve rattle bad
fordtractorpro
PostPosted: Tue Nov 13, 2012 11:30 am    Post subject: 8n valve rattle bad Reply to specific post Reply with quote
I bought a 8n non runner. Hope it ran,it had 45 lbs of oil pressure cranking. I got to messing with it today. Replaced the carb and some priming up and running. Problem i encountered was the WORST valve rattle i have ever encountered. Beside pulling head and doing the obvious anyone think a valve lash adjustment might cure it ?
TheOldHokie
PostPosted: Tue Nov 13, 2012 12:07 pm    Post subject: Re: 8n valve rattle bad Reply to specific post Reply with quote
fordtractorpro wrote:
(quoted from post at 15:30:14 11/13/12) I bought a 8n non runner. Hope it ran,it had 45 lbs of oil pressure cranking. I got to messing with it today. Replaced the carb and some priming up and running. Problem i encountered was the WORST valve rattle i have ever encountered. Beside pulling head and doing the obvious anyone think a valve lash adjustment might cure it ?
Maybe - if it has adjustabe lifters.
TOH
R Geiger
PostPosted: Tue Nov 13, 2012 12:09 pm    Post subject: Re: 8n valve rattle bad Reply to specific post Reply with quote
(quoted from post at 04:30:14 11/14/12) I bought a 8n non runner. Hope it ran,it had 45 lbs of oil pressure cranking. I got to messing with it today. Replaced the carb and some priming up and running. Problem i encountered was the WORST valve rattle i have ever encountered. Beside pulling head and doing the obvious anyone think a valve lash adjustment might cure it ?
Might help IF it has the adjustable lifters installed. Also might not be valve rattle. Might do a compression test before removing the head.
Den N Ms
PostPosted: Tue Nov 13, 2012 3:19 pm    Post subject: Re: 8n valve rattle bad Reply to specific post Reply with quote
fordtractorpro ,Pull the covers off the side for a look see.Roll it over and look for sticking valves,excessive valve stem clearance.If you still don't see the problem,then start it up and listen with the covers removed.
HCooke
PostPosted: Tue Nov 13, 2012 3:28 pm    Post subject: Re: 8n valve rattle bad Reply to specific post Reply with quote
No personal experience, but a worn cam gear will cause a rattle, or so I've been told.
