7810 pto problem
agtrac
PostPosted: Tue Nov 13, 2012 6:16 pm    Post subject: 7810 pto problem Reply to specific post Reply with quote
Hey everyone, I've got a 7810 S that started out with the pto not disengaging, I pulled the lift cover and found the brake band broken so I decided to take the clutch pack and valve assembly out to inspect everything, I found worn clutches and valve support arm seals worn etc so I replaced the clutches and drum, the support arm and valve, put everything back together and now the pto shaft wont turn under a load, any ideas what can be causing this, it feels like I have no hydraulic pressure but all the other hydraulics work fine, I'm at a loss...
Bern
PostPosted: Tue Nov 13, 2012 6:25 pm    Post subject: Re: 7810 pto problem Reply to specific post Reply with quote
I'm guessing that you did not get the pressure pipe clipped in place good. However, this would also affect the dual power as well.
RodinNS
PostPosted: Tue Nov 13, 2012 7:23 pm    Post subject: Re: 7810 pto problem Reply to specific post Reply with quote
Or he didn't get the shaft fully seated in the clutch pack... or the correct torque on the support arm locator screws for the clutch. Most likely the supply line tho.
Rod
agtrac
PostPosted: Wed Nov 14, 2012 2:53 pm    Post subject: Re: 7810 pto problem Reply to specific post Reply with quote
thanks guys for your replies and your help, but found out that the tractor serial number on the frame says its a 7810 but its actually a 7810S so the new clutch pack valve was wrong, got the correct one on order and should solve my problem...
