| Author |
Message |
Larry Bingham New User
Posted: Wed Nov 14, 2012 2:56 am Post subject: JD 50 Compression Test |
Did compression test on JD 50. 60 PSI on both cylinders. Seems low to me. What should compression be? I have IT Shop Manual, but can't find what it should be. All I can find is compression ratio. |
| Back to top |
F-I-T Tractor Guru
Joined: 27 Feb 2002 Posts: 8447 Location: United States
Posted: Wed Nov 14, 2012 3:37 am Post subject: Re: JD 50 Compression Test |
| Larry Bingham wrote: | | (quoted from post at 03:56:42 11/14/12) Did compression test on JD 50. 60 PSI on both cylinders. Seems low to me. What should compression be? I have IT Shop Manual, but can't find what it should be. All I can find is compression ratio. |
FSB 236 says at teh speed using the starter, a gas engine should read 118 psi, and an All-Fuel 91.5 psi.
Did you test it with the throttle wide open and both plugs out? |
| Back to top |
Dodgeit Long Time User
Posted: Wed Nov 14, 2012 8:13 am Post subject: Re: JD 50 Compression Test |
| Larry Bingham wrote: | | (quoted from post at 05:56:42 11/14/12) Did compression test on JD 50. 60 PSI on both cylinders. Seems low to me. What should compression be? I have IT Shop Manual, but can't find what it should be. All I can find is compression ratio. |
I had one that only read 60psi in both cylinders as well. Altough that seems low she pulled like a freight train so I just chalked it up to restricted air flow. |
| Back to top |
F-I-T Tractor Guru
Posted: Wed Nov 14, 2012 9:25 am Post subject: Re: JD 50 Compression Test |
| Dodgeit wrote: | (quoted from post at 09:13:53 11/14/12) | Larry Bingham wrote: | | (quoted from post at 05:56:42 11/14/12) Did compression test on JD 50. 60 PSI on both cylinders. Seems low to me. What should compression be? I have IT Shop Manual, but can't find what it should be. All I can find is compression ratio. |
When you get one that low, unless there is a chunk of deposit in the intake area restricting air flow into the cylinder, you should squirt a couple pumps of oil in, spin it few times, and measureit again. If it comes up, it's likely the oil has sealed worn rings. If it stays low, suspect a leaking valve. Then it's time for a leak down test, and use a length of garden hose to listen through hose to determine where the air is leaking out. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
